Trailer Troubleshooting?
/ Trailer Troubleshooting?
kenmac said:
Can you (or) have you jacked the trailer up & run a hot wire straight from the batt. & connect it to the hot wire going to the trailer brakes ? ( without going through the brake controller ) If the wheels lock down doing this , I would say it is the controller.
Thing is and this is what has got me if it is the controller particularly since it has worked up until now, is that I hooked up my truck to the horse trailer and the system worked then. The difference between the horse trailer wiring and the flatbed wiring is that the horse trailer doesn't having any wire on just the accessory position and on the flatbed I just have right and left turn, brakes, and ground everything else is open.
/ Trailer Troubleshooting? #12
its fairly common for Green to be right turn-brake
Yellow to be left turn/brake
brown to be running/tail lites
rest of wires are ground and brakes and possibly accesory
/ Trailer Troubleshooting? #14
The last poster (Egon) has the link you need to see. The blue wire is for the brakes as shown. Using a 12V jumper wire touch it to the trailer plug blue wire while someone checks each wheel on the trailer to see if the magnet is energizing. If not you may have a break in the wiring or a bad magnet in the hub.
The most common problems are corrosion in the wiring plug terminals, corroded wire inside the truck or trailer plug, bad or missing ground, broken wire under trailer possibly ripped off by a road hazard. I rarely get more than a year on mine before I have to rewire the plug. Winter road salt around here just gets inside the plugs and works its magic.
/ Trailer Troubleshooting? #16
George2615 Winter road salt around here just gets inside the plugs and works its magic.[/QUOTE said:
after you wire a new one, I usually seal the end with RTV.
also some grease in the plug.
doesn't stop corrosion but it does slow it down.
/ Trailer Troubleshooting? #17
I do use grease on mine. Have tried silicone sealant but the salt always finds a way inside. My 2006 tilt bed trailer with need a repaint this year already. It looks about ten years old right now. I don't mind the snow, just hate the overuse of road salt.
/ Trailer Troubleshooting? #18
How I check each wheel brake is I hook up a battery charger to the plug and run an extention cord to the rear. Jack up each wheel and plug in cord to power the brakes and spin test.
All trailer plugs and recepticals have a specific pin position and wire has a color code. Some people don't follow the codes.
2007 Ford Crown Victoria Sedan (A59231)
2007 Ford Crown...
DEUTZ MARATHON...
2008 Regal 2565 Express Cruiser Boat with 30ft T/A Continental Boat Trailer (A59231)
2008 Regal 2565...
2018 23ft. Carolina Skiff Ultra Elite Boat with 24ft. T/A Boat Trailer (A59231)
2018 23ft...
2007 MACK CHN613 DAY CAB (A59906)
2007 MACK CHN613...
2017 Nissan Altima 4 door (A61307)
2017 Nissan Altima...
