Trailer tongue leveling and brake controller questions
   / Trailer tongue leveling and brake controller questions #11
I got my drawbar flipped tonight, and the trailer looks real good now. But it was quite a spectacle getting the work done. For whatever reason, I could not get the ball loosened from my original drawbar. In fact, I actually tore my vise off my workbench cranking on it with a long wrench. That threw me backward onto the hood of my wife's car, and sent a chainsaw on a nearby shelf flying in on top of me (thankfully it was in a scabbard). Talk about nuts. After that, I decided to just buy a new drawbar and ball -- I'll fight with the old one another day once I get my vise remounted. The new drawbar dropped me an additional 1/2" compared to the old one, and now things look just about perfect when loaded up.
Please post a video reinactment for our pleasure. :) Glad you weren't injured or the car damaged.
Those lockwashers do bite into the nut very well. I have a very large vise and a big ***** wrench and it is still tough.
   / Trailer tongue leveling and brake controller questions #12
Yup, something about trailer hitch components, when they get stuck they stay frozen. I know a guy that worked all day getting an insert out of the receiver tube. I've had balls I couldn't break free, even with a monster vise and 4 foot wrench. Heat til they're red hot will do it, but that's not good for their metallurgy.
JB
   / Trailer tongue leveling and brake controller questions #13
I have no problem changing balls on my hitch, I leave it on the vehicle and with a socket to fit and a breakover handle you have the whole truck to be your vice. Speedy2
   / Trailer tongue leveling and brake controller questions #14
I bought one of these... http://www.maxbrake.com/
None of the time based or inertia brake controllers compare. Neither do surge brakes. I will never go back.
   / Trailer tongue leveling and brake controller questions #15
I second this.This is what I usually do.
I think on both of my vehicles I've got my voltage set at 6.0 on the brake controller (as recommended by prodigy). When towing my utility trailer empty I use no boost. With a load I will go to boost level 1 or 2 depending on the load. With the stock trailer empty I will run it at boost level 1, with load I will go to boost level 2. When I tow the camper (with the truck only, I won't use the 'burb on this) I take it to boost level 3. Quick and easy and I can adjust it on the fly. No skidding tires and I can actually feel the trailers "holding their own" so I think it is working pretty well.
BTW, if you find your tongue is still a bit low with the 2" drop, I used to use a hitch on my S10 with a 2" drop and a ball with a 1" rise. Worked perfect for my need at that time.
   / Trailer tongue leveling and brake controller questions #16
I have seen some so bad, like they were welded. if you beat them that hard you could damage your receiver, break the socket or wrench.
JB
   / Trailer tongue leveling and brake controller questions #17
JB
I came out of my garage one day listening to my next door neighbor trying again and again to start their old Taurus in the driveway. It was their High school kids car they had picked up used. After a few minutes of listening to endless cranking, I went over to offer help. First thing I did was ask them to pop the trunk as that is where the fuel pump cutoff switch is in that Ford (all Fords have them). Sure enough it was popped up so I reset it. They couldn't figure out how, but it started right up then. I said it takes some kind of an impact. Then the light went on. The Dad was beating the daylights out of the hitch that was rusted solid into the receiver to get it out (unsuccessfully). So I saved them a tow/mechanic trip and they learned something... Yeah they can weld in there pretty good. He left it alone after that.
   / Trailer tongue leveling and brake controller questions #18
S219,
It sounds like your brakes are not strong enough to lock up even at full voltage, but plenty strong to add a lot of breaking force. I had that situation on one of mine and decided I needed more for mountain towing, so I changed to 5200 lb axles and brakes from the 3500 lb setup I had. What a difference! It may not be a good idea to lock the trailer brakes, but it's also good to have reserve power, if needed, on long downgrades where fading can occur.
Locking up on a curve would be the worst thing, but in icy conditions that could happen even with weak brakes. Too bad we don't have anti-lock trailer brakes. I suppose, if you only have brakes on one axle in a tandem setup, the lockup issue would be less important, but the braking would be less too.
I changed to a Brakesmart controller and will never go back to the inertial or de-celerometer design. But even those need adjusting with varying loads and different trailers. I always set mine so the trailer is pulling slightly back on the truck. It aids stability and reminds me it's working
   / Trailer tongue leveling and brake controller questions #19
Just want to mention that prodigy doesn't recommend a setting of 6.0. The output should be adjusted based on the weight of the trailer, road conditions, etc. For example, they should be readjusted if it starts to rain. For safety you want to try to set them right below the point of lockup. None of my current 3 trailers will lock up the brakes even at full gain when loaded so I set them at 10 when the roads are dry. I post a copy earlier of the manual. Might want to revisit it. Please don't take this the wrong way, just trying to be helpful.
Jeff
   / Trailer tongue leveling and brake controller questions #20
Raspy said:
S219,
I agree. 3500 lb axles have a 10" brake drum. You get a 12" on the 5200 lb axle. Smart move for the mountains but your suspension might be too stiff unless you used your old springs. Antilock brakes are available but expensive.
2007 Case IH 275 Tractor (A59814)
2007 Case IH 275...
*Selling at Royal Auction Tampa, FL Location* (A59230)
*Selling at Royal...
2022 John Deere Z930M (A57148)
2022 John Deere...
1987 FORD F-700 FUEL TRANSPORT TRUCK (A58214)
1987 FORD F-700...
Willmar 4550 Wrangler Articulating Loader (A56438)
Willmar 4550...
Landoll 876C Soil Finisher (A59814)
Landoll 876C Soil...
