Trailer tire clearance
/ Trailer tire clearance #1
cford36
Western, NY
LS3135HC
I have a 7500# trailer. The concern I have is that I have noticed that it does not seem that there is room for full travel before the tires will rub the fenders. I just replaced the tires, same size but upgraded from C range to D. The tires do extended slightly outside the fenders. When fully loaded I cannot put my finger between the tire and fender, so when going over something they appear to rub the fender.
What should be the normal clearance? I am considering moving the fenders up higher for more clearance. I will post pictures when I get some.
/ Trailer tire clearance #2
What size tires are on it now? A 7500# trailer should have 205/75/15 or 14's. A 225 is usually too big and causes the issue you are having.
Chris
They are 205/75/15, same as the the ones I took off. Only difference is the load range, which I don't think should make a difference in size.
These are the old tires but it looked the same unloaded.
/ Trailer tire clearance #6
These are the old tires but it looked the same unloaded. <img src="http://www.tractorbynet.com/forums/files/trailers-transportation/381955-trailer-tire-clearance-img_0204a-jpg"/>
Yours look like the same amount of clearance and bow legged as mine. I think your axles will hit the frame before you hit the fenders.
Chris
/ Trailer tire clearance #7
Here is a pic of mine loaded down and they never rub.
Chris
/ Trailer tire clearance #8
I have on one trailer taken an adjustable wrench and radiused the fender lip where there may be contact with the sidewall. If you do small bends at a time it looks pretty good.
/ Trailer tire clearance #9
or remove the fenders and space them out slightly, if they are not welded on
2014 TEXAS PRIDE GOOSENECK TRAILER (A67714)
2014 TEXAS PRIDE...
2017 VERMEER TG7000 TUB GRINDER (A66091)
2017 VERMEER...
2021 Kubota BX2680 25HP 4WD Utility Loader Tractor w/ Attachments and 2021 T/A Flatbed Trailer (A66734)
2021 Kubota BX2680...
213086 (A64276)
213086 (A64276)
2012 PETERBILT 337 FLATBED W/ LIFTGATE (A67714)
2012 PETERBILT 337...
2013 CHEVROLET CAPRICE POLICE CAR (A66091)
2013 CHEVROLET...
