Trailer selection....
/ Trailer selection.... #31
Dovetails do make for easier loading, but may not be the best choice if you live in a hilly area. Both my previous 16' and my current 18' have dovetails, ending about a foot off the ground. The only problem is that the departure angle is terrible, and I live on a hill. I decided that the trade off was worth it, but scraping the tail every time I go in or out of the driveway does get annoying. One more factor to consider...
/ Trailer selection.... #32
That is true. It is flat as a pankake around here. I sure would not do without a dovetail as it has spoiled me. The other day I had to till a gardend that was about 25x50 for a lady. I was just curious how long it would take so I started the timer when I stopped my truck. I unchained and unloaded the tractor, tilled the garden, collected my $$, loaded and secured the tractor with 4 chains and boomers and was back in my truck driving away 21 minutes later. It seems like I have spent taht much time messing around with ramps on other trailers.
/ Trailer selection.... #33
</font><font color="blue" class="small">( I would get a trailer with a dove tail. After having messed around with ramps and getting them set right and then going to this I will never go back. My trailer is a 18' 7000 lb tandem car hauler with a dovetail. The back is only about 1 foot off of the ground. I approach the trailer slowly and can drive right on without ramps. I do commercial work so am unloading and loading several times a day and it makes it much easier and quicker. Also no ramps to worry about tearing up or losing. My trailer is a bit small for my tractor as I am right at 7000lb if you take into account the weight of the trailer but it is working fine. )</font>
You think my ck30 would just drive up onto a dovetail? Sounds nice!
2014 RAM VAV 2000 TRAILER MOUNTED VACUUM MACHINE (A59823)
2014 RAM VAV 2000...
TOPCAT HCRC 72" HYD BRUSH CUTTER (A52706)
TOPCAT HCRC 72"...
2016 Ford Fusion AWD Sedan (A59231)
2016 Ford Fusion...
2010 Honda Accord Sedan (A59231)
2010 Honda Accord...
2000 ITASCA SUNCRUISER 37G CLASS A RV (A60736)
2000 ITASCA...
2011 DOOSAN G25KW GENERATOR (A58214)
2011 DOOSAN G25KW...
