Trailer paint recommendation
/ Trailer paint recommendation #1
Sarge338
Bronze Member
Mahindra 2555
Time to overhaul my 16’ equipment trailer, and while I have the floor torn off of it, I have been thinking about painting it. Does anyone out there have a recommendation for paint for the metal on my trailer? I’m sure some people just shoot Rust oleum on there, but I’m wondering if there is a better/longer-lasting option that I can shoot from a pneumatic sprayer.
Thanks!
/ Trailer paint recommendation #2
I've never sprayed with it but I have brushed on POR-15 on many items (trailer frame included) that has held up well for many years. It is expensive though. I have also sprayed rustoleum but hasn't lasted as long as POR.
/ Trailer paint recommendation #3
I think priming and painting with Rust-Oleum is the most cost appropriate way to go for a trailer. Remember that POR isn't UV stable and needs to be top coated.
/ Trailer paint recommendation #4
Review the Project Farm website. He has had some of the better product reviews, and I believe there was one about spray paints, and durability.
However, I would encourage you to use automotive paint. Go to your favorite auto paint shop. Get a can mixed up in your favorite color. Prime with a good epoxy primer, and then do a couple of layers of top coat.
The stuff isn't cheap, but it should give you the best overall finish.
/ Trailer paint recommendation #5
The best paint I have ever used is Vaspar Implement paint. Among other things, I painted the bucket on my skidsteer. Even gravel didn't take it off!
edited ; Sadly, Valspar no longer sells implement paint.
Thanks for the replies. I will look into all of them. I have to make some modifications to the trailer first, anyway, so I have a little time for research.
/ Trailer paint recommendation #7
I painted a trailer decades ago with Dupont Imron and looks like new...
A friend was moving and gave me the paint...
/ Trailer paint recommendation #8
A single stage urethane is the best way to go, as far as durability. But, that gets real expensive, depending on the color, the level of quality you chose, and what you use under it. You need to find out what is available locally. Ask what they can mix in a lower end, single stage urethane. AIC from Sherwin Williams automotive is a good choice for a project like this, if you can get it.
AIC™ 2.8 and 3.5 VOC Acrylic Urethane | Sherwin-Williams
As a more cost effective option you can go with the industrial enamel, (Rustoleum).
A big part of the longevity is the prep, and the undercoats, (primers), you use. You can use high end products under industrial enamel, and get good corrosion protection, without spending a small fortune. Even though the paint will fade, or lose it's gloss, the metal is still be protected. You can always clean it, and blow another coat of paint on it down the road to bring back the gloss.
/ Trailer paint recommendation #9
Rustoleum is durable, lasts extremely well, and it is very easy to do touch-ups as needed.
And it's cheap!
I painted the headache rack on my truck 4 years ago with their gloss black spraypaint, and it still looks new.
/ Trailer paint recommendation #10
I had the frame of my old Land Cruiser media blasted to bare metal then applied three coats of two-part black epoxy primer with UV inhibitor.
/ Trailer paint recommendation #11
You could skip the bare metal strip with a good pressure wash and apply Black Star rust inhibitor. No top coating needed. Turn a black - dark purple color.
/ Trailer paint recommendation #12
I just used Rustoleum Equipment enamel on a steel roof. I have high hopes
/ Trailer paint recommendation #13
Farm Implement paint works for me
/ Trailer paint recommendation #14
I have seen a two part epoxy used with good results. It was black, can not remember the manufacture.
/ Trailer paint recommendation #15
Another vote for Valspar tractor and implement paint, for which they also offer a spraying thinner and hardener. But also won't say anything negative about Rustoleum, I'm actually using that on my trailer right now, because it was easier to source locally. Both are alkyd enamels, and the durability of both more dependent on thickness (coats) and cure time, than any difference between the two products.
I have used 2-part products as well, but likely not woth the effort on a trailer. Most are linear polyurethanes with isocyanate hardeners, that are very sensitive to moisture. There are just too many opportunities for that to go wrong if you're spraying outdoors, unless you happen to live in Arizona.
/ Trailer paint recommendation #16
/ Trailer paint recommendation #17
Thanks!
Without proper prep, Nothing works
With proper prep, just about anything will do the job.
Heck, from my experience the mfg of most trailers don;t even use primer!
/ Trailer paint recommendation #18
I used to sell that stuff 50 years ago. If it approached $100 a gallon then,what does it cost today? Google didn't really tell me.
/ Trailer paint recommendation #19
You also need to be very careful using Imron or other similar products. If you are not, you could destroy your lungs and die.
Attention (A57148)
Attention (A57148)
2015 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A59230)
2015 Chevrolet...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
2015 Doosan 750CFM T/A Towable Air Compressor (A59228)
2015 Doosan 750CFM...
2020 Caterpillar D5K2 LGP Crawler Tractor Dozer (A56857)
2020 Caterpillar...
2004 Ford F-550 Miller 301 Wrecker Truck (A55852)
2004 Ford F-550...
