Trailer Mover Build
/ Trailer Mover Build #1
94BULLITT
Super Member
USA
yes
I started with a $3 hitch.
I cut the hitch down, added clevis hookups and a piece of 2x2 for the upright.
I added some gussets, a piece of 2.5x2.5 on top so I can move a gooseneck and can use it for future attachments.
I need to make my mind up on how I am going to add the chain to keep the 3PH for rising while moving a trailer then clean and paint it.
/ Trailer Mover Build #2
Nice job, way to recycle that old hitch!
Dave
/ Trailer Mover Build #3
Looks good.
Get a flat strap, maybe 2x6x1/8. Drill a 3/4 inch hole in one end and a smaller one in the other. Put your top link pin through the 3/4 hole and a chain shackle through the other. Chain the shackle to your stationary drawbar. Remove the chain when not using the trailer mover, but leave the strap in place for next time.
Bruce
/ Trailer Mover Build #4
Looks like a gooder-un :thumbsup:
/ Trailer Mover Build #5
Looks good. Wish I would have thought of that, could probably pick up a hitch at a pull apart place pretty cheap vs buying the steel at the store like I did.
Thanks guys. I am not the first person to have the idea on recycling the hitch.
Bruce,
I bought a little over 9' of 3/16" chain at Home Depot, that was all they had. I was going to weld a repair link to the trailer mover and use a piece of the chain to connect it to the drawbar when I need it. I decided I don't want to cut that chain and put hooks on the end of it:laughing: I'll keep your idea in mind. I was thinking about welding a piece to the trailer mover and with a hole in it like a rollback bed had so you can just drop the chain in it and you don't need a hook.
/ Trailer Mover Build #7
Is it possible to just lock the 3ph once you have hooked on the trailer and lifted to height? Or will the lock still allow for lift? Right now I just have a ball on my box blade and it has more than enough weight to counter any momentary loss of tounge weight on the trailer, but I have been wanting to build a similar set up.
/ Trailer Mover Build #8
I've been lowering my 3ph under my trailer tonques for over 10 years now and just lift the 3ph and drive away. If it a heavy load of firewood logs or similar I might snap the hitch closed but most times I just lift the drawbar into the hitch, making sure that there is ample tonque weight. Most times I keep a 1 7/8 ball in the receiver, but I can switch to 2" or 2 5/16" if I really need to (seldom). Don't recall ever having the tonque lift the 3pth except once when someone loaded the first bucket of gravel on the rear of the trailer. Even then we just loaded the next bucket farther forward.....
I made the thing for the chain. I just need to weld it on now.
/ Trailer Mover Build #11
Very nice indeed, now just needs some paint:thumbsup:
I do have one question though about the 2.5x2.5 tube on top for the GN.
Was that seemless tube?? Did you test fit an insert before you welded it on??
I made a few of them out of 2.5x2.5 tube when at my old job. Just like the one you can buy @ tsc that are about 8" long or so. But 2" tube wouldnt fit with the seam. So I had to take a long end mill and knock the seam out (had to hit from both ends as the mill was only 6" long). Just wondering about your situation???
Thanks for the comments.
LD1, I used a die grinder with a deburring tool to clean up the inside of the 2.5x2.5 tube.
Log lifter attachment. with 5/16 grab hook and clevis. I need to make a plate for the lower receiver to keep a log from hitting the tractor.
Winch mount. The handle was made out of a leaf spring ubolt, the right side of the winch has a place to put your hand. I doubt I will use it on the tractor any but I can if I need. I am going to use it primarily on my car trailer. I also have a winch set up the same way for my 6x14 trailer.
I'll get some better pictures once everything is painted.
The winch mount is painted and ready for use.
I needed to pick up my trailer to get the ramp out. I tried using the pallet forks on the BX but it would not lift it high enough. I put the log lifter on the trailer mover and was able to pick it up high enough.
/ Trailer Mover Build #17
Don't understand why you have to pick it up to get the ramp out?
Not to get it out but to remove it. They have a piece of angle welded to the end to keep you from pulling them all the way out. I had to pick the trailer up so I could tip the ramp down to remove it.
/ Trailer Mover Build #19
Okay, now I understand, you removed it.
Next question, why did you remove it?
It was bent, it was that way when I got it. So I straightened. I am going to sell the trailer.
WARREN POWER SYSTEM LIGHT PLANT (INOPERABLE) (A68842)
WARREN POWER...
ENCLOSED OPERATOR CAB (A67714)
ENCLOSED OPERATOR...
Unused 2022 WIFO WBGS Hydraulic Bale Grabber Skid Steer Attachment (A66734)
Unused 2022 WIFO...
2009 TRAIL KING PNEUMATIC TRAILER (A67714)
2009 TRAIL KING...
PORTA POTTY (A68842)
2015 Ford F-250 Ext. Cab Animal Control Service Truck (A66736)
2015 Ford F-250...
