Trailer modification help.
/ Trailer modification help. #1
radman1
Elite Member
midwest
JD 4520, Toolcat 5610, Bobcat S300, Case-IH 125 Pro, Case-IH 245, IH 1086, IH 806
I am considering buying a utility trailer. It has been on the dealers lot for 2-3 years. It is 82"x20' with 15" metal side wall, 12,000 lb rating and mesh rear ramp gate. I like the rear gate for loading smaller stuff such as ZTR. However, I would like to occassionally load my JD 3720 CUT or Toolcat. I think the mesh gate won't be strong enough. If I beef up the tailgate, it may get too heavy to easily lift. Suggestions? I have considered making a set of regular ramps to lay over the mesh gate and then load heavier stuff. I could store them under the trailer. Could just reinforce the mesh gate where the TC and CUT tires travel? TC weighs over 5K plus attachments.
/ Trailer modification help. #2
You could use a elegator or gorilla lift for assistance with the weight of the trailer gate after modifications. A search in G**gle for "trailer gate lift system" returns plenty of options. I was going to reinforce the mesh gate on my first trailer, but then a good deal came up on another trailer.
Carl
/ Trailer modification help. #3
Weld 2-3 pieces of angle iron under the mesh where the tires will go, that should be enough without adding a lot of weight, if you cant get it up easily, something like a gorilla lift will work wonders (and I would recommend it if you have a single piece gate)
Aaron Z
2012 PROCCO 130BBL (A65643)
2012 PROCCO 130BBL...
2022 John Deere 5055E (A60462)
2022 John Deere...
Applegate Creep Feeder (A66408)
Applegate Creep...
Case SV280B (A60462)
2023 Big Tex 16GN 102''x40' Gooseneck Trailer (A64127)
2023 Big Tex 16GN...
1987 FORD F-350 CUSTOM SERVICE TRUCK (A64280)
1987 FORD F-350...
