Trailer Locks
/ Trailer Locks
Trailer tongue locks will not even slow down a thief. They just lay the tongue on the bumper. wrap the safety chains around the bumper and drive off. Then deal with the lock later. Google wheel locks. They are similar to the boot locks the police use. There is a lot of steel to cut and the thief may not notice the lock and create quite a scene trying to drive off.
Maybe need to look at the boots better.
/ Trailer Locks #13
Wouldn’t taking a wheel be easier than a parking boot? Unless there’s something special about your trailer making it the direct target its likely the would be criminal would move on to an easier target. Kinda the same logic that you don’t have to outrun the bear, just the next slowest person.
/ Trailer Locks #14
Another option I just thought of assuming it’s a heavier trailer would be to leave the jack in the lowest position and take the handle. Sure, you could use a pipe wrench and jack it back up or use another jack, but how many would be criminals carry those tools?
/ Trailer Locks #15
I use acetylene tank caps and use a regular security lock that latches around the safety chain attachment point.
So the safety chains attach to the trailer the same way they attach to the truck and are not there to attach to. I also machined my own jack that is removable so they cant just jack it up and tie anything around it.
536563d1516460734-trailer-locks-42d5969d-44b1-43f0-9c2a-0668fe3c8a70
All that does is slow down a thief or make the lazy one look for an easier one to steal.
I worked at on place, that like clock work would have one trailer stolen every 3 day weekend. Actually had one with a removable tounge (jack, hitch and all back to the frame of the trailer) and all 4 wheels and tires removed from it. It too was stolen, with a flat bed wrecker.
/ Trailer Locks #16
/ Trailer Locks #17
I have an equipment trailer and a dump trailer. When I leave the place, one of them gets wedged back into some trees where it cannot be got at except with a tractor. The other I hook the backhoe over the tongue and disable the backhoe. Also none of this is visible from the lane that goes by our place or from any other property.
The highway department removes the wheels from powered sign trailers and such that they leave by the side of the road.
The tongue lock OP posted has a cross bar that could be cut with a cordless grinder in probably 20 seconds. There are other models that put more metal in the way and might be more resistant. Similar to jwmorris approach.
/ Trailer Locks #18
The main usage of the majority of trailer lock devices will be to deter the impulse theft.
Any targeted trailer will succumb to an experienced thief.
LOL I liked the welding tank cap idea. Genuine KISS solution.
I am not a thief but did help a friend 'repo' a rented out trailer that the renter was very much in arrears with the rent.
The guy used 3/8 graded chain thru a rim and looped it around a hefty tree and a HD lock.
With a battery grinder and thin cutting disk we were hitched and gone in about 5 mins.
We were nice guys however as we only cut the last link at his padlock.
Oddly enough the renter never reported the trailer stolen to my friend.
When he came to rent he was driving a nice flashy new SUV thus creating a good impression.
Oh, and he had about 1/2 dz sheriff notices on his door so we were not the only ones being stiffed.
/ Trailer Locks #19
I’m not a thief either but I’ve cut through about a dozen lost key locks with my cordless grinder. It takes less than a minute even for the big heavy ones. I’ve cut plenty of chains and cables for a re hook. Again it’s no challenge. To stand any chance of working you need to protect the lock for access with a grinder and abandon the idea of chains or cables.
/ Trailer Locks #20
The best anti theft devices are generally unknown, because if it is not stolen you do not know what worked. One of the simplest anti theft device is
an alarm sign. If they think there is an alarm they may go to a different target.
2005 All Pro L7077 (A60462)
2005 All Pro L7077...
Kubota L3130 (A53317)
2001 INTERNATIONAL 4900 WATER TRUCK (A58214)
2001 INTERNATIONAL...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
SALTYS MANFUFACTURING 500BBL FRAC TANK (A58214)
SALTYS...
LaneShark L53 (A60463)
