Trailer build
/ Trailer build #21
When I built mine I welded the hangers to heavy angle. I botlted the angle to the channel face with a couple of grade 8, 1/2" bolts. This will allow for sliding the axle and redrilling the anchor holes if you need to adjust for tongue weight.
/ Trailer build #23
Why did you choose to mount the leaf springs below the axle?
It gives you a lower clearance to give ground. That way the trailer is lower all around and easier to load
1989 AM General M998 HMMWV 4x4 Humvee Truck (A59230)
1989 AM General...
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2019 CHEVROLET...
2023 Kubota L6060HST Compact Utility Tractor (A61307)
2023 Kubota...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
MARATHON 20KW GENERATOR (A58214)
MARATHON 20KW...
2003 Coachmen Catalina Sport 220RK Class C Motorhome (A59231)
2003 Coachmen...
