Trailer build
/ Trailer build #21
When I built mine I welded the hangers to heavy angle. I botlted the angle to the channel face with a couple of grade 8, 1/2" bolts. This will allow for sliding the axle and redrilling the anchor holes if you need to adjust for tongue weight.
/ Trailer build #23
Why did you choose to mount the leaf springs below the axle?
It gives you a lower clearance to give ground. That way the trailer is lower all around and easier to load
2008 FORD F-550 SUPER DUTY (A60736)
2008 FORD F-550...
ATTENTION! PLEASE READ (A60463)
ATTENTION! PLEASE...
CASE IH STEIGER 400 HD TRACTOR (A58375)
CASE IH STEIGER...
New Holland 3930 (A60462)
New Holland 3930...
MAGNUM PRODUCTS LIGHT TOWER (A60736)
MAGNUM PRODUCTS...
iDrive TDS-2010H...
