trailer brakes
/ trailer brakes #11
there are so many different wiring diagrams and trailer connectors, between round pin and flat, 6 or 7 .
if you goggle trailer connector pin outs you can find all the different ones and the color codes.
Trailer Wiring Diagrams | etrailer.com
Of course that assumes things are properly wired with standard color codes. Trailers are often wired with non-standard colors, especially older ones. Not sure if truck manufacturers color code the OEM plug wiring or not.
The gold standard is always testing it yourself. Either with a multimeter, test light or fancy $10-20 plug tester (which is just a handful of test lights on a plug). The Etrailer page lists out what pins do what if you scroll down.
/ trailer brakes #12
Got nothing to do with the trailer plug.
He stated his brake lights were on the truck soon as he connected the brake controller. Then the brakes automatically locked on trailer once he connected it up. Tells me the trailer is correct.
/ trailer brakes #13
Possible. It depends if the trailer was plugged in when he connected the controller. The wiring fault could be in the trailer. I'd consider a trailer more likely to have issues than a truck. But if the trailer isnt connected & things are going wonky, ya, definitely an issue with the truck or brake controller.
/ trailer brakes #14
Not sure if it makes a difference or if it's different on a Dodge but my F150 required the installation of a relay in addition to the harness and adapter. My truck came from the factory trailer brake controller ready but I had to supply the controller. The tow package had the adapter harness and the relay in a bag in the glove compartment. My Tekonsha Prodigy controller plugged right in and worked perfectly.
You problem sounds more like something is wired incorrectly though. See if you can find a different trailer to plug it into for comparison. That would tell you if it's on the truck or trailer side.
/ trailer brakes #16
You have something miswired and can be the trailer of the truck. Looking at the parts obtained and installed in the truck, my first thought is there is something with the trailer. The link posted by Fallon in post 11 would be the one to check out. The trailer may be back feeding the lights and brakes
/ trailer brakes
not saying the trailer isnt the problem but it is a brand new homesteader brand trailer. i called hopkins support and he said it could be the control box. now, as rocketfish said, im wondering if it might be that the ground is not good enough for the brakes. ive read that brakes require a real good ground but all of the lights on the trailer work. anyway i appreciate all of yall trying to help me get this fixed
/ trailer brakes
finally got my trailer brakes fixed, called hopkins customer support and he had me do some tests and determined that the controller box was faulty. took it back to autozone and they exchanged it. hooked it up and now everything is golden. again thanks to all of for helping me
/ trailer brakes #19
Glad to hear that it's working. That makes sense as to why it was misbehaving the way it was.
Aaron Z
Toro Reelmaster 6500 D (A61166)
Toro Reelmaster...
Case SV280B (A60462)
2001 Subaru Outback AWD SUV (A59231)
2001 Subaru...
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2019 CHEVROLET...
1995 John Deere 7400 (A60462)
1995 John Deere...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
