trail clearing technique and tools
   / trail clearing technique and tools
The tools along while blazing.
And the help.
   / trail clearing technique and tools #943
Try wrapping your hand/wrist when using the brush cutter.
And, wear a wrist brace at night. I too will wake at night from carpel tunnel pains in my hands but sleeping with a simple loose "wrist brace" is all it takes to get through the night.
I've found that the combination of land work (amateur/hobbyist) and computer work (professional) can wreak havoc on the hands and wrists.
Don't forget the muscles that open/unclench your fingers and the ones that pull the wrist back away from the grip - usually when I have wrist pain I can do some light wrist reverse curls, with a small dumbell or other weight, and this helps the wrist greatly.
Even if you look like those muscles are heavy duty on your arm, you can probably use a bit more concentrated strength there to balance - if when you stand with your arms relaxed at your sides, if your wrists automatically curl in a bit you're probably out of balance.
Basically put your arm, palm down, across a bench or counter so that the forearm is supported; grasp a weight in the hand, gently lower your wrist down with gravity, pull back up - only flexing the wrist. Repeat. Make sure you use a light weight, I'm serious, most of us other don't use these muscles much.
The fellow with the wrist grief has not responded since.
While on a hike over the 4th, in northern MN, we passed a power line grade that had been freshly brushed. All I ever seen doing this job is a skidsteer with a carbide toothed spinning thing. What are they called? I'd like to know how they miss the rocks!
Today I picked up a kubota tractor owned by a good Samaritan who likes our trails. With it today I smoothed out some lumps of dirt left by a logging company to improve drainage for our parking lot and snow removal. Plus I knocked out some old stumps I hit while plowing. On Saturday i will be mowing with it.
   / trail clearing technique and tools #948
Pretty trusting of a guy to lend his cabbed tractor for work in the woods.
   / trail clearing technique and tools #949
Arly, I believe they are called forestry mulchers. They are quite the machines and are expensive. I know they also take a lot of hydraulic flow to run them to. I suspect they start out with the head held high and work their way lower with it to avoid rocks but I’m not sure. Like everything I suspect they get skilled.
Looks like your solidly in the tractor shopping mode after borrowing that bad boy. :) Nice of him to lend it to you.
2005 Caterpillar 928G Articulated Wheel Loader (A55973)
2005 Caterpillar...
2022 JOHN DEERE 624P WHEEL LOADER (A52707)
2022 JOHN DEERE...
60in Forks (A56857)
60in Forks (A56857)
PALADIN INDUSTRIAL SCREENER (A58216)
PALADIN INDUSTRIAL...
Fleco Log Forks (A59213)
Fleco Log Forks...
2016 Ford F-150 Pickup Truck (A55973)
2016 Ford F-150...
