trail brush maintenance - Samurai Cutter - Sicklebar or similar option?
   / trail brush maintenance - Samurai Cutter - Sicklebar or similar option?
if it works as good as the videos, and lasts, it sure would make the job easy, maybe even enjoyable.
   / trail brush maintenance - Samurai Cutter - Sicklebar or similar option? #33
It works for these good ol boys.
good video there, I just wish there was more info out there, and other than what was published by the manufacturer.
Sure does 'look' like it would be a great solution for my situation.
   / trail brush maintenance - Samurai Cutter - Sicklebar or similar option? #35
I have the same type of fence row trail clearing. I said to heck with privacy and took out the scrub and left the tall trees. Once a year I use a small push mower around the 3 rows of trees to clip the small sprouts and the trail gets cut with the Cub Cadet. Yes, it was a bunch of work on my hands and knees cutting everything flush to the ground but it looks nice now. We have Buck-thorn that never stops invading uncut areas.:mad:
My wife does the same, and anything else she can run over, which is why she got 2 new deck belts for Christmas (for real), she uses it like a mini bush hog. It's lasted 10+ years, so while not pristine, it works.
   / trail brush maintenance - Samurai Cutter - Sicklebar or similar option? #37
If you really want to get serious ...
that thing is awesome!
   / trail brush maintenance - Samurai Cutter - Sicklebar or similar option? #39
I really wish I could find some actual user / owner feedback on the Stout Designs unit. I would also be curious if they could make a hydraulic motor powered version that could run off a third function.
   / trail brush maintenance - Samurai Cutter - Sicklebar or similar option? #40
That is an intriguing unit. If it could stand up to Rhododendrons, I'd have to seriously consider it to keep our roads from growing in.
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A53472)
80in HD Tooth...
1999 Ford Ranger Pickup Truck, VIN # 1FTZR15X6XTA79787 (A51572)
1999 Ford Ranger...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A52377)
2003 Big Tex 10PI...
2001 Blaw-Knox PF 150 Paving Machine (A52384)
2001 Blaw-Knox PF...
(1) 14ft Tarter Gate (A51573)
(1) 14ft Tarter...
2015 Ram 3500 Enclosed Service Truck (A52377)
2015 Ram 3500...
