Richard
Super Member
- Joined
- Apr 6, 2000
- Messages
- 5,046
- Location
- Knoxville, TN
- Tractor
- International 1066 Full sized JCB Loader/Backhoe and a John Deere 430 to mow with
"The farm needs a haircut" Lots of branches encroaching into the fields and all....
I debate every now & then on attaching a side mounted mower to my International.....or buying another tractor with it mounted like you see cutting the right of ways.
I think I've primarily seen New Hollands. I have nothing against the brand nor for them. Totally agnostic.
Couple questions....
Irrespective of the brand one might buy.... Do people (Municipalities) generally buy these kind of machines already "tricked out" by the manufacturer or, does the owner (Municipality) buy raw tractor....raw mower, put things together and build the safety cage/screen on the tractor?
If someone ends up with a machine like one of these, can that SAME machine pull say, a 15' flexwing mower behind it such that you can merrily cut your fields and when you want to push the tree line back a bit, you change controls....... or, does it mandate a second machine?
My recollection is that the hydraulic pumps that might be on these are rear PTO mounted so unless you have a front PTO, I'm guessing you can have one or the other but not both? (why not plumb both into same pump system but have operation switchable to either/or mower?)
Who "makes" these? (makes as in takes the raw parts and creates a finished side mowing machine that is ready and safe to use)
