2022 Schulte SMR-800 Multi Rake Landscape Windrower (A56435)
Item Details
Auction ID
56435
Make
Schulte
Type
Ag Equip
Year
2022
Auction House
Fastline Auction, LLC
Model
TSMR
North Carolina
Description: The perfect multiple use, heavy duty landscape rake. The roto-tilling action of the SMR-800 breaks lumps, roots and other debris while reclaiming rocks by forming them in uniform rows. The 4-inch replaceable teeth give you greater ground penetration and are made of wear resistant 450 hardened steel. The SMR-800 is chain driven to keep the hydraulic motor out of harms way. Option for standard solid mount or floating mount that can pivot up to 20 degrees left or right, manually or hydraulically. Solid mounted or hydraulic lifting 23-inch forklift grade tires for increased maneuvering and rugged durability. High or low flow hydraulic options. Heavy-duty chain drive: The hydraulic motor is protected and the chain runs in an oil bath with a reversible tensioner. Floating mount option: A floating mount is available that can pivot up to 20 degrees left or right, either manually or hydraulically. Adjustable side plates: These can be mounted on the front or back of the unit and are adjustable, reversible, and removable. Roto-tilling action: This helps to break up lumps, roots, and other debris. Deeper penetration: A larger bottom sprocket in the gear ratio provides increased mechanical advantage for deeper ground penetration. Weight - 1900lbs Drum Width - 89 inches Transport width - 102 inches Hydraulic Flow - 18-25 gpm Drum Speed - 220 to 250 rpm Tires - 23-inch Forklift Teeth - Replaceable 2.5-inch and 4-inch made of Hardox 450 hardened steel Year: 2022 Make: Schulte Model: SMR-800 Serial No.: R50020260210 Tire Size: 6.50-10 NHS Stock No.: A0725 FASTLINE SALES REPRESENTATIVE(s) Bobby Kennerson bobby.kennerson@fastline.com 502-222-8303 Item Location - Address: Provided by Seller Item Location - City: Franklinville Item Location - State/Province: North Carolina Item Location - Postal/Zip Code: 27248 Item Location - Country: United States
This is a online bidding auction by Fastline Auction, LLC
see lot description, multiple locations, KY 40010
Starting Bid: 7500.00 USD
Auction Finishes: December 02, 2025 at 05:44 PM
Click Here To Bid Now!
Happy Bidding!
2017 Polaris 500 Ranger Diesel Utility Cart (A55787)
2017 Polaris 500...
2019 Ford F-350 (A55973)
2019 Ford F-350...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
Portable Restroom (A54865)
Portable Restroom...
John Deere skidsteer (A55788)
John Deere...
2014 Ford Taurus AWD Sedan (A56859)
2014 Ford Taurus...
