Tractors and wood! Show your pics
   / Tractors and wood! Show your pics #5,372
That log, at 20 + feet long was too wide for the road and on top of that, it weighed over 3000 pounds...
It was just faster/easier to pull it home...
SR
Good excuse to get a BIGGER tractor?? :)
   / Tractors and wood! Show your pics #5,373
The tie rods on the Kubota tractors I have seen are ahead of the front axle but well above the front axle. My thinking is if you want a skidder then buy a skidder.
gg
Of course I'd want a skidder. Used to drive em. The tractor will have to do as I cannot afford a skidder and buying a used (read "used up") skidder is like buying a tumor that was removed from someone else.
I've under armored my tractor but I still bent the tie rod that is "above and behind" the front axle. There are woods and then there are woods and rocks and stick ups and no "roads" to consider. Any tractor that lives at my house best be able to stand up to how I have to use it. And although I think Kubota makes some of the best machines, An L3000 something Kubota at my place would have been a weekly tie rod fix without fabrication of some sort.
   / Tractors and wood! Show your pics #5,374
SR
My little Junior will handle this one what's your tractor's excuse.
   / Tractors and wood! Show your pics #5,375
Some are more for the forrest than others:
Forest
   / Tractors and wood! Show your pics #5,378
   / Tractors and wood! Show your pics #5,379
I spent yesterday cleaning up the last two storms, and part of today refilling my wood box. I wanted to work on the load of spruce I'm cutting; but between the snow on the trees and the knee deep stuff on the ground it didn't happen. Right now there's too much on the ground for my tractor to go anyways except on my existing trails or within winching distance from the plowed road; plus I won't be able to get a truck here to haul it until the ice on the road subsides.
Let me know when you want to work on a load of cedar. Two weeks ago had a ft of snow so now figuring on around 10" more, should be a blast.
2014 DITCH WITCH RT45 RIDE ON TRENCHER (A51246)
2014 DITCH WITCH...
FRONTIER AV50H LOT NUMBER 111 (A53084)
FRONTIER AV50H LOT...
2005 GENIE S-80 MANLIFT (A51246)
2005 GENIE S-80...
Rear Tine Garden Tiller (A51573)
Rear Tine Garden...
Modine Shop Heater (A51573)
Modine Shop Heater...
1839 (A51248)
1839 (A51248)
