Tractor Wood Splitter
/ Tractor Wood Splitter #1
Larry Caldwell
Super Member
Myrtle Creek, Oregon
Kubota l3130
I need a wood splitter, and the commercial ones with small engines seem pretty slow. I'm thinking about either buying a pre-built one or building my own out of a splitter with a bad motor. The ones I have seen on YouTube seem to run best with about a 20 gpm PTO pump. That cycles a 5" ram in about 6 seconds, both directions with about a 24" stroke. My tractor only puts out 8.3 gpm at the valve, so I think it would be no faster than one with a little motor.
Tractor powered hydraulic log splitter - YouTube
In any case I need something that rotates to vertical, because I have oak rounds as big as 3' to split and I can't lift them. I assume I need something in the 30 ton range to get the work done. That means a pretty good sized cylinder. I think my tractor would probably handle a 25 or 30 gpm PTO pump with no problem.
Has anybody tinkered with something like this?
/ Tractor Wood Splitter #2
Why don't you build a log lifter? After my wood splitter was stolen I'm going to have to build one. The plan is a horizontal only with a log lifter, wedge on the end of the beam, and a large table to catch the split pieces. Here's about what I have in mind. image-3761013816.jpg image-421006399.jpg They claim a 10 second cycle time with 22 gpm which is acceptable to me. My other splitter did 13 seconds. I wished it was faster, but it wasn't that bad. I plan on building a self driving unit with a lawn mower conversion. I'll probably end of scrapping that idea in favor of a self driving unit propelled with the lawn rear end and powered with the lawn mower engine which is a 18 hp Briggs&Stratton vanguard. I don't want to power it with my loader tractor because it needs to move wood. I could power it with the B7200, but it'll probably be sold in the feature.
/ Tractor Wood Splitter #3
My pto splitter has a 20 gpm pump on the pto with a 5" cyl, and it works very good.
Keep in mind, all the ports, hoses and valves ALSO have to be rated for at least 20 gpm too, and you need a 15 gallon or so hydraulic tank on it too...
SR
/ Tractor Wood Splitter #4
SR
Exactly. A tank is required. And a vent, should have a filter too. Tanks are often 1 gallon per each GPM to help cool the fluid.
Mini Skid Steer Mount Plate, 5/16" Thickness (A62679)
Mini Skid Steer...
3pt 20' Cultivator (A64119)
3pt 20' Cultivator...
NEW WATER PROOF/FIREPROOF FIRST ALERT SAFE (A64281)
NEW WATER...
2022 Chevrolet Tahoe SUV (A61574)
2022 Chevrolet...
2008 Detroit Diesel 200PJS6DT3 200kW Diesel Generator (A61572)
2008 Detroit...
APPROX (50)UNUSED CORRUGATED METAL SHEETS (A64281)
APPROX (50)UNUSED...
