Tractor won't start
/ Tractor won't start #1
gooddirt
Mahindra E-Max 25
I have a mahindra emax 25 and it wont start. I turned the key for warm up then when the glow plug indicator went out I turned the key the rest of the way for start. It went click and every thing went dead. I got out the test light and started checking. I have power to the starter, also to and from the ignition switch but nothing comes on not even the flashers. What could be my problem?
/ Tractor won't start #2
It could be a battery near the end of its useful life or just dirty or loose connections. Remove battery cables and clean connectors. Clean battery terminals. Reinstall cables and tighten securely. If you can move them they're not tight. Follow the ground lead to the frame. Clean and tighten. Measure the battery voltage - should be about 12.6. While monitoring the voltage have someone attempt to start the tractor. If it drops to ten volts it's probably marginal. Below ten it's time for a new one. If the battery voltage holds and the starter won't turn the engine over we'll go from there. Oh, and welcome to TBN.
/ Tractor won't start #3
I recently had the same issue with my Branson, found a connector that came unplugged under the dash coming off of the ignition switch. As mentioned earlier make sure the battery is fully charged.
/ Tractor won't start #4
Look around on ground beneath engine for the wiggle pin in case it fell out of wobble shaft.
/ Tractor won't start #5
Welcome to TBN. I would start with battery ground connection, then all battery connections.
/ Tractor won't start #6
I'm sure you have numerous safety switches . . . check them.
/ Tractor won't start #7
Just curious, when you used it last was the pto engaged
/ Tractor won't start #8
Welcome to TBN. You will find most here will do their best to offer useful information, reasonable discussion, or silly tired jokes.
Checking TractorData.com indicates your tractor is a minimum of 6 years old and may be as much as 8 or 9. If you haven't replaced the battery since the tractor was new, it may be at the end of its life. You didn't indicate a region you live which can be perinate information for those trying to help with a parts source or just to have an idea of weather conditions which may exacerbate starting problems and battery life. I don't know where you store it, but look for rodent nests and possible chewed wires plus all the other advise about tightening connections and testing,
Regarding your region, you don't need to be specific if you don't want to, but an area helps. For instance I could have put north central WA or Okanogan. or even just eastern WA and it would be enough.
/ Tractor won't start #9
Roadworthy posted a good place to start.
My contribution would be that an independent of the machine battery load test would be best, and could be the source of the no start condition. Of course, it could be plenty of other things.
Your failure was identical to two failures that I had a few years ago on my diesel zero turn mowers (same exact failure, 2 different machines). My failure was a catastrophic battery failure on 2 optima batteries that were 3 years old. The resting voltage was somehow normal, zero under load.
/ Tractor won't start #10
I had very similar problem with my 2 year old 5545 where I shut off the tractor and the next time had a click and then nothing. I checked all battery connections and they were all tight. I assumed battery was low and tried to jump it with but still had a click. Removed the battery and did a load test and battery was ok. I removed both cables and found the ground cable connection to the frame had the frame painted with about 1/4 inch of bare metal exposed. Cleaned the frame the full area of the cable connection to bright metal and reconnected the ground cable. Problem solved.
/ Tractor won't start #11
I had a similar problem so I called the dealer and explained I was using the Rotary Mower and I turned the PTO off and the motor. Now it won’t start…. They told me sometimes the PTO Switch sticks (in the on position) and won’t let the tractor start. I checked it out and that’s what the issue was, problem solved.
/ Tractor won't start #12
The same happened to me when I flipped the PTO switch but it wasn't quite in the off position. I call the dealer and they had no idea. I found the problem myself.
/ Tractor won't start #13
This may have nothing to do with your problem, but my emax 25 had some electrical issues which came from the wire harness rubbing against the front 4wd driveshaft. Terrible design. Look along the inside of the left frame.
/ Tractor won't start #14
/ Tractor won't start #15
I have Mahindra Max 24 that had the same issue. After lots and lots of checking and testing it turned out to be dirt packed in & around a safety switch. Good luck
/ Tractor won't start #17
A clicking sound when attempting to start anything usually means that the starter is not receiving the required power to turn over. If so, it's either your battery or a safety mechanism preventing the system from turning over. For example, if you did leave the PTO on and it's attached to a shredder, trying to start the tractor is applying a huge burden to turnover not only the engine, but also the PTO and shredder. The safety mechanism is preventing this so you won't damage your starter.
There are a lot of good suggestions here, try them and post back.
/ Tractor won't start #18
Please check to see if your PTO is engaged it may have a safety sw on it w/ a broken contact j
/ Tractor won't start #19
This is where having a manual with a good schematic helps. If even the flashers don't work now I'd suspect you've lost your main ground from the battery. I've had an instance where I had a vehicle with fusiable links in the cables themselves, one burned out and that was it I was stuck until I could replace it. I'm assuming that you use your test light by grounding it on a convenient spot on the tractor and then touching the positive lead of the circuit you're checking. If so, this does nothing toward checking the grounding. Use an ohmmeter and check between the negative terminal and the chassis, you should have near zero ohms. Note: I'm assuming that your Mahindra is negative grounded, it may not be.
/ Tractor won't start #20
I am having issues with Mahindra Max 26 XL Starting. Checked all common safety switches and not that. Based on every thing I have been reading I feel its likely wiring/moisture issues. When I turn key to turn on glow plugs I get a different sound and some times nothing and no dash lights or power at all. Battery is brand new and took out all fuses and all good. Tried to restart and made weird sounds again with dash lights flickering. The third try it fired right up like normal. Second time this has happened in the past month. Has to be bad/loss wiring. Does any one have some some pictures of the common wiring trouble spots to check first before I just start tearing in to all the wiring? I do need to check my glow plug connection which I will do tomorrow. Thanks for any insight. I have learned a lot from reading various post on the topic already.
2019 Harley-Davidson FLHTP Electra Glide Motorcycle (A66738)
2019...
JOHN DEERE 7330 PREMIUM TRACTOR (A64280)
JOHN DEERE 7330...
Polaris Ranger 4x4 Gas Utility Cart (A66734)
Polaris Ranger 4x4...
2025 Kubota RTV520 4x4 Gas Utility Cart (A66734)
2025 Kubota RTV520...
2018 GENERAC MOBILE PRODUCTS MTL6S (A67714)
2018 GENERAC...
2011 Chevrolet Express 2500 Cargo Van (A66736)
2011 Chevrolet...
