Tractor Won't Start
/ Tractor Won't Start #1
haussie
John Deere 5205
Any advice is greatly apprreciated. I've been troubleshooting as much as I know. I have a John Deere 5205 Tractor. When I turn the key, the engine cranks, but won't start. First I thought battery was the issue. Installed new battery - same issue. Tried jumpstarting - no change. Battery terminals are clean.
Fuel is moving thought the lines. White smoke is coming from the exhaust.
Checked all fuses - all ok. Neutral and seat switches are working normally. Air filter is clean. Checked the fuel shutoff - ok. Lights dim as I crank.
Thanks in advance for any advice.
/ Tractor Won't Start #2
What is the temperature ? Could be fuel gelling if very cold and no/insufficient anti-gel additive. Are the glow plugs or air preheater working? Dirty/plugged fuel filter? Fuel solenoid working?
/ Tractor Won't Start #3
i know you said you checked all fuses, but check them with an ohm meter. this sounds exactly like a problem my neighbor had with his new JD tractor. turned out to be a bad fuse, even though it looked ok.
i tested them all with tester, found a suspect one. replaced it and the tractor fired up
/ Tractor Won't Start #4
If your machine is cranking, but not firing/starting, and it is a JD - it could be your fuel shut-off solenoid. It sounds as if you have checked all the low hanging fruit.
When you turn the key to the first position - "on" but not cranking, do you hear a loud click up by your fuel rack, down stream of your fuel filter? If not it could be the fuel shut-off solenoid that is the problem. Our dealer has been selling them like hotcakes lately, I had the same problem and replaced it ($187.00 freaking dollars) and it worked fine, for six starts then the new one failed - was replaced under warranty - a freak occurrence, I hope. The cold weather caused the original one to fail.
Best of luck.
Thanks for all of the advice. I think I've got a bad starter. Tried a few more things and this time noticed smoke coming from the starter - not good. Pulling the starter off and going to replace.
/ Tractor Won't Start #6
Be sure and check for water in the fuel, or a plugged filter. If the engine is spinning over, then the starter probably wasn't the issue to begin with. It might be now if you have ground on it a lot trying to get it started.
I agree with above. Look at the fuel shutoff selenoid. My little tractor clicks and then rattles with the key in the on position.
STACK OF METAL TRUSSES (A63291)
STACK OF METAL...
2016 Chevrolet Silverado 1500 Pickup Truck (A64194)
2016 Chevrolet...
Caterpillar D6D Tractor Service and Parts Manuals (A63117)
Caterpillar D6D...
Caterpillar 345B/BL Excavator Service and Parts Manuals (A63117)
Caterpillar...
1069 (A64280)
1069 (A64280)
2018 John Deere 5125R Tractor (A64047)
2018 John Deere...
