Tractor Weight & SideWalks
/ Tractor Weight & SideWalks #1
AltaLawnCare
Gladys, VA
I've been comparing NH, JD and Kubota. I'm leaning towards a Kubote 2910 now because the weight is just under 2,000LBs.
I figure with a loaded bucket & operator it will be around 2300LBs. This is a max of 575LBs per Tire. Would this weight be safe over concrete sidewalks?
Thanks, Billy.
/ Tractor Weight & SideWalks #2
That might depend on how thick the side walk,and how old the cement is.
I would be extra careful in the spring time when the frost is thawing.
/ Tractor Weight & SideWalks #3
My answer would be yes. You should of course avoid customer's concrete for cracking reasons but also to not leave black tire tracks.
At a previous work place, I watched in amazement a landscape contractor operate a Ford 1920 on a new sidewalk to move topsoil and resod next to sidewalk. It probably wouldn't hurt the crete but he had the manpower there to wheelbarrow everything and that is what I would do out of respect for the client.
Also, I recently had a good chuckle out of seeing a skidsteer perfecly bottomed out on an elevated sidewalk that still needed back filling
/ Tractor Weight & SideWalks #4
You can't trust the weight values that Kubota lists on its web site. I think Muhammad recently verified that these are "shipping weights" and do not include wheels, or tires and possibly some other stuff. Bottom line: the Kubotas are much closer in weight to the similar sized JDs and NHs that their specs would lead you to believe. In any case, I would not be afraid to drive any of the small or mid-sized tractors from any manufacturer across my sidewalks. Hope this helps.
/ Tractor Weight & SideWalks #5
I think you should double check those weights. I believe the B2910 weighs in around 1750 lbs. or so without the loader. I don't have my manuals in front of me, but I think the loader and bucket adds an additional 800 lbs. or so.
Unloaded the B2910 and loader will weigh somewhere in the 2500-2600 lb. range. Add a full bucket (300-600 lbs) and add 200 lbs. for the operator (speaking for myself) brings a total over 3000 lbs. Then, if rear ballast is added, the combined weight might be 3500 lbs. or more.
I don't think a properly installed and seasoned sidewalk should be damaged by this weight. I haven't noticed any problems on our asphalt driveway and sidewalks.
I don't believe any of those tractors would be a problem for the sidewalks, but if weight is a concern, then the B2910 should be able to be the lightest of the group.
Good Luck,
Rick
Thanks everyone,
I had my doubts about their weight claims. I'm still leaning towards the B2910.
/ Tractor Weight & SideWalks #7
Depends upon the sidewalk... I'd stay off corners or any part that isn't well support underneath. That said, I run my L2850 with loader and backhoe all over my sidewalks with no problem.
/ Tractor Weight & SideWalks #8
Most exterior concrete is 3500# psi after 28 day's. If you do the math you can see there shouldn't be any problem. A few hundred pounds one way or the other probably won't make any difference.
/ Tractor Weight & SideWalks #9
that weight should not be a problem. most delivery trucks (ups) and such weigh more than that.
/ Tractor Weight & SideWalks #10
Some trivia picked up at work, if anyone's interested. We had to have labs crush test cylinders of concrete for work we have done. At the construction site, the plastic test cylinders are poured. They are roughly 6" in diameter and maybe a little over a foot in height. The lab does a minimum of two breaks, and I forget when the first one is done - think it's 7 days - then a second break at 28 days. I never saw it done, but was told they cut slices from the cylinders and crush them by placing the slices in a machine that records the PSI applied at failure. The "weight" or compressive strength of concrete is the amount of pressure applied to crush it between two smooth surfaces, and does not indicate a sidewalk, floor, wall or bridge deck will hold that weight. What it does is verify that the material is up to specification for the engineer's design of the assembly, which may include reinforcing steel, compacted earth, etc. An example would be a floor that is designed for a 250#/SF load. The design may use 4,000# concrete, that doesn't mean the floor will hold 4,000#/SF. It means the test machine will need to apply at least 4,000PSI to crush a sample of the concrete. If everything else used to build the floor is also up to spec and installed properly, it will hold the 250#/SF plus whatever safety factor the engineer has built into it.
I live where there are freeze/thaw cycles, and the concrete plants need to know if the concrete they are sending to the job is for interior or exterior use because the concrete used for sidewalks and such are to be "air-entrained" to help avoid damage from Mom nature......................chim
/ Tractor Weight & SideWalks #11
Let's think about this. My truck, with a load, weights about 6,000 lbs. I use a truck tire on it. The tractor weights about 3,500 with FEL, bucket full, me and a box scraper. The tires are wide on the rear and spread out the load. So, me thinks that a truck on the sidewalk gives more lbs per square inch than my tractor. I've never given it any thought, just went over them without concern and NEVER had a problem.
Turfman
/ Tractor Weight & SideWalks #12
Keep in mind engine fluids as well.
As for asphalt, it is fairly plastic , and would most likely deform on the surface, rather than cracking.
For what it's worth, I drive my NH 1920 on my 1 year old driveway ( 3" 2000 psi concrete w/standard wire reinforcement, and fiber mix added )
Tractor is around 3700 with me and an implement on back.
The most I've done is leave black tracks on the concrete.
your millage may vary.
Concrete is very good about sustaining high psi loads, and problems usually only occour during flexing, torsion, or uneven loading near an edge or tip.
OTOH a 13 ton garbage truck HAS cracked my drive when they backed onto it... arrgh!
Soundguy
/ Tractor Weight & SideWalks #13
Assuming you are using a concrete spec'ed for 3500 psi...
Soundguy
"Most exterior concrete is 3500# psi after 28 day's. If you do the math you can see there shouldn't be any problem. A few hundred pounds one way or the other probably won't make any difference. "
/ Tractor Weight & SideWalks #14
Yes, what they are measuring is the ultimate compressive strengthof the concrete, and record what load was carried prior to failure.
Against a solid foundation, I would be surprised if 1sf of 4k psi concrete would not carry a 4k# load, with even distribution, w or w/o wire reinforcement.
""The design may use 4,000# concrete, that doesn't mean the floor will hold 4,000#/SF. It means ""
We also use fiber addatives for added durability to stress.
""sending to the job is for interior or exterior use because the concrete used for sidewalks and such are to be "air-entrained" to help avoid damage from Mom nature......................chim ""
Soundguy
/ Tractor Weight & SideWalks #15
i leaned a trick when i was drafted into the US Army. while stationed in germany we had to take our tanks across roads and sidewalks of the real world, not in a training ground ... and if i understand this is what you want to do, go across not travel on the side walk?
the trick we learned and i am now using whenever i have to go across walkways with my landscaping equipment (cement, natural stone path etc) we use the same method as i learned from the US tankers, we lay down 2x12 by however long we need it boards and have been lucky so far to never damage anything.
good luck
2008 Trail- Eze Tilt Triaxle, 42' Deck/10' Neck (A62679)
2008 Trail- Eze...
2011 WESTERN STAR  4900SA  SLEEPER (A65643)
2011 WESTERN STAR...
1995 Peterbilt 379 Tri-Axle Dump Truck (A61573)
1995 Peterbilt 379...
New/Unused ATS T460 Mini Skidsteer (A65583)
New/Unused ATS...
1997 Peterbilt 379EXHD Day Cab w/ Wetline (A62613)
1997 Peterbilt...
L-Shaped Fuel Tank Hose and Electric Pump (A62679)
L-Shaped Fuel Tank...
