Tractor Storage
/ Tractor Storage #1
Anonymous Poster
Epic Contributor
I have a JD 4100 and see many people keeping tractors outside and uncovered. This seems like a bad thing, but I am curious what most people do and what is recommended. How much of a difference if it is under something like a carport, vs. in a shed or garage?
also
How do you keep mice from invading the engine or tractor?
thanks
/ Tractor Storage #2
<font color=blue>see many people keeping tractors outside and uncovered</font color=blue>
So do I, Carl. I live in farming country and it never ceases to amaze me to see the amount of farm equipment sitting outside rusting. The only thing I can figure is that they depreciate it on their income taxes and things like that. I just couldn't leave mine sitting out like that; my tractor AND all my implements are inside my shop building.
/ Tractor Storage #3
Even under a good tarp will make all the difference in the world compared to left outdoors. I had to leave my IH2500b outdoors for several years, and man did the rust get started in the places that you can't easily see. At least I tarped it in the winter, but then the mice got the seat. Once, somone popped the door open and something ate a rabbit on the seat. I now store it inside. I also store my new PT425 and all of the implements inside as well.
<font color=green> MossRoad </font color=green>
/ Tractor Storage #4
My JD 955 is home in a heated garage, the 1050 and boom flail is in a co-workers pole building. The Befco 6' rotary mower is outside, and not by choice. The JD 25A flail is riding in the back of my 1 ton dump truck. I'd rather have everything in. Hopfully in the spring we can get the new home going, along with the 30 x 48' pole building.
Paul
/ Tractor Storage #5
I keep my tractor in a 3 stall pole barn I originally built for my horses (have since sold them).Here in N.C. the humidity gets to the tractor no matter what, unless you have climate controlled storage, so I keep it and my implements in the barn to keep the rain and dew off them.
Wally <font color=green>JD 750 "GATOR"</font color=green>
/ Tractor Storage #6
I keep my tractor and as many implements as I can in the shop. The rotary cutter doesn't fit, but I keep it under an extended roof overhang and stake a tarp over it just for good measure.
My neighbor leaves his tractor and implements outside all year around, and you can really see the difference. /w3tcompact/icons/tongue.gif
/ Tractor Storage #7
carl
I keep mine under cover at my father-in-law's next door until I ever build my pole barn. I always put the seat up so animals don't get on it(cats). They can really tear up a seat with their claws.
Jerry
/ Tractor Storage #8
I keep mine behind doors and what a different compare to others that don't who bought the same time as I did.
Fading paint,extra work when snowfalls,harder to PM etc...
If you got and area make the room,for your just protecting your investment that much longer.
Thomas..NH /w3tcompact/icons/wink.gif
/ Tractor Storage #9
I was forced by circumstances beyond my control (read: broke) to leave most of my implements out in the snow. I tarped everything I could, but still...
Circumstances finally consipired to convince my wife that the barn I'd been whining about for 5 years was worth going into debt for. Now everything is under cover, even if it's just a three-sided pole barn. Even my raggedy old manure spreader.
Of course, my two pickups still sit out in the snow all winter. I wonder if I can swing another loan...
/ Tractor Storage #10
Carl,
I keep my 790 in an old horse stable (now converted to a tractor shed). As much as we pay for these things, we really ought to try to protect them from the weather.
I have to store my tractor for long periods of time (months), so I keep everything well greased, the tank filled as full as possible (to prevent condensation), and the entire tractor up on blocks (to prevent flat-sides on the tires). I also remove the battery and store it in my father-in-laws garage. So far, I havn't had any problems.
As far a mice go.... keep the D-Con out and plenty of traps. Damage from nesting mice is likely to be the thing that gets my tractor one of these days....
Henry
/ Tractor Storage #11
Carl, I keep my 4100 inside of one of my garage bays sitting on top of my Trailer. i have the trailer lowered with the wheels off and on jacks and ramps. It provides me with a raised platform for working on it and it allows me to keep both of them inside protected from the elements.
/ Tractor Storage #12
I keep my JD 4100 in my 10'x10' garden shed when I have the FEL off. Otherwise, I can't shut the doors. It has been stored outside for a few weeks at a time when I was using the FEL a lot. Luckily, that was when we had our draught period. A building of some sort is in the planning stages. I'm leaning toward a small bank barn to take advantage of my terrain.
As far as mice, one of the problems with living in rural areas. Just have to work around the little buggers. Cats, traps, and DCON rule!!
Terry
/ Tractor Storage #13
Here is mine in the garage, on the trailer.
nuru
/ Tractor Storage #14
Much to my wife's dispair, I built a raised shed on a concrete slab 16X18 with overhead door to store my JD and implements.And would you believe it?, its filled already.
/ Tractor Storage #15
Hi Carl,
I came across this end-of-year special on Cover-It sheds and had to order one to keep my 4400 young. Check it out a special@canopyfactory.com (forgive me, but I don't know how to make the address into a link).
Mike
2010 Case 580N (A60462)
2010 Case 580N...
Snow Plow & Salt Spreader (A62613)
Snow Plow & Salt...
2022 Caterpillar 262D3 (A64126)
2022 Caterpillar...
2010 Sterling A9500 T/A Day Cab Truck Tractor (A61568)
2010 Sterling...
2011 Ford F-350 Crew Cab Service Truck 4x4 (A62613)
2011 Ford F-350...
New/Unused ATS Electric Jack (A65583)
New/Unused ATS...
