Tractor Storage
/ Tractor Storage #1
Sailorcrew
Londonderry, NH
Kubota L3010, loaded r'4s and an Ingersoll 4018
Here's a two part question: I live in New Hampshire and it gets fairly cold up here in the winter. I will use my tractor less in the winter, may even go a month or two (gasp!) between uses. The only use may be to clear the snowpiles so generously left by the town plow crew. I have a large snowblower for the driveway. Any precautions? I did read that the clutch pedal should be depressed and secured with the hook to relieve pressure. How about letting the diesel sit during this time?
The other question: At some point I will build a shed for the tractor. Currently, I can fit it into the garage, manuver it sideways and still have room for the cars. Doing this, though, does take time and definately takes up some space. Not to mention the risk of running over numerous bicycles, scooters and rollerblades. I want to build a shed large enough for the tractor, say 16' by 20' or 20' by 20'. It would also hold the various other items for the tractor along with the blower, lawnmower, etc. Having a brand new Kubota, I won't let it sit outside and am even reluctant to let it sit in an unheated shed over the winter. This is probably not a valid concern but did want thoughts on this, especially the cold climate dwellers. David
/ Tractor Storage #2
DAVID,
my suggestion. build a shed bigger than you can afford, because it will never hold
everything that you want to put in it. i sure wish i had made mine larger.
accordionman
william l. brown
/ Tractor Storage #3
Sailorcrew:
Storing it in cold weather, say -40F, would not be any problem. My 7100 had that treatment for years. Starting it though will be impossible.
Either install an inline antifreeze heater or be able to bring the shed up to +32F or so and then youve got it made. Also make sure you put winter diesel in it.
It will rust less if stored unheated.
Now if you have trouble finding a spot to build your storage shed I'm sure I can find a place for it!!!!
Egon
/ Tractor Storage #4
Bill:
Amen to that. My shop is 24x36 with 10' ceilings and I already wish it was bigger. Build the biggest you can't afford and I guarantee it still won't be big enough.
P.K. Burke
2019 GENERAC MDG75DF4 TOWABLE GENERATOR (A63276)
2019 GENERAC...
T/A Drop Deck Equipment Trailer (A64556)
T/A Drop Deck...
SHOPBUILT S/A TRAILER (A64278)
SHOPBUILT S/A...
Bull (A64557)
Bull (A64557)
2017 Ford Expedition SUV (A64557)
2017 Ford...
2018 MULTIQUIP TOWABLE GENERATOR (A63276)
2018 MULTIQUIP...
