Tractor Spotlight
/ Tractor Spotlight #1
NHmitch
Platinum Member
SW New Hampshire
Bolens G154/IsekiTX1300F
I have been tired of working the dark behind the my tractor at night in the woods. I use to have a utility light mounted on the tractor b, but I could not really aim where I needed it, si I purchased a spotlight that was meant for an ATV, but it worked great. Its a Blazer ATV spotlight, and it fit perfectly on my fender handle. I was able to quickly wire it under the seat where the wire is connected to the fender lights. The spotlight does not rattle, or move when I drive, and I can aim it anywhere I need it, and it is very bright. All this for $25. Not a bad purchase. Excuse the clutter behind the tractor..
url
/ Tractor Spotlight #4
Do you have a link to where you got it from? Such a thing would be perfect for some things I need to do...
Aaron Z
/ Tractor Spotlight
I bought it from Tractor Supply, but if you do not have one near you, they have them on Amazon,: [ame=http://www.amazon.com/Blazer-C8014-Spotlight-Black-Housing-1/dp/B000EFIT8G/ref=sr_1_1?ie=UTF8&qid=1336062736&sr=8-1]Amazon.com: Blazer C8014 ATV Spotlight with Black Housing-1 each: Automotive[/ame]
It works great, and it will lock in whatever position you want to aim it. You can remove it from the stand and hold to top aim if you need to as well. Hope that helps!
/ Tractor Spotlight #6
Thanks, will look into one of those to put on the tractor for some extra light when haying.
Aaron Z
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2020 CHEVROLET...
2019 BOBCAT E45 EXCAVATOR (A63276)
2019 BOBCAT E45...
McCormick X6.55 (A64126)
McCormick X6.55...
Case 950 8 Row Air Planter (A63118)
Case 950 8 Row Air...
2018 Kenworth W900 Ext. Day Cab (A62613)
2018 Kenworth W900...
2008 Ford F-450 Flatbed (A62613)
2008 Ford F-450...
