tractor speed
/ tractor speed #1
tonyw
NC
YM1401d
I'm looking into purchasing a small Holland transplanter to pull behind my YM1401d. Fortunately, they have a transplanter that will fit my Yanmar, but the salesman said the tractor would need to drive no faster than .02 mph in order to operate the transplanter effectively.
If I put it in low 1, will that be slow enough? /w3tcompact/icons/hmm.gif Does anyone have info on operating speeds in various gears?
Thanks very much!!
tony w
/ tractor speed #2
Are you sure about .02 mph?? That's really slow. The travel speed chart for my 186D shows .61 mph as the slowest speed (at 2600 rpm). I'm not sure I have ever used first range.
Chris
/ tractor speed
Chris,
Yep, he said 2/10ths mph..I think I mistakenly siad 2/100ths!/w3tcompact/icons/shocked.gif. Anyway, I'm attaching an image of the very basic model which mentions the speed.
Thanks for any help!
/ tractor speed #4
Tony,
My YM1301D manual shows 0.94 km/hr (0.58 mi/hr) in low range 1st gear at 2400rpm. I think the YM1401D is geared much the same. To get to 0.2 mph, I would need to run the engine at 800 rpm. I don't think I could effectively do much with my YM1310D at 800rpm.
Greg
/ tractor speed
Thanks, Greg! Ugh!/w3tcompact/icons/mad.gif wouldn't you know it--just when I think I've found a solution..well, I'll do some more checking with the folks at Holland because I really want to make this work, to save my aching back!!.
Besides, there are lots of extras you can buy to go along with the transplanter--and you know you can never have enough toys!/w3tcompact/icons/grin.gif
I'm thinking that speed is for really closely spaced plantings--less than 6 inches. Since my spacings are more like 12-18", I might be alright in low 1?
thanks again for all your input!
tony w
/ tractor speed #6
Tony,
Low 1 really seems slow to me. I'd find it hard to believe that you couldn't do it.
By the way, I assume you are planting pines, spruce, firs, etc for tree farming??
Greg
/ tractor speed #7
I have never tried it but I see no reason that you couldn't creep across the garden at .2 mph running the engine at 800 rpm in first gear first range. It's not like you are going to be loading down the tractor.
Chris
/ tractor speed
Greg,
It sure seems that low 1 would be slow enough--it certainly seems slow enough whenever I'm tilling in low 1.
Actually, all of our trees are container-grown. We start plants in our greenhouse(annual flowers and perennial flowers/shrubs), then we transplant them into our field in spring--we cut and sell the flowers/foliage to local florists, a wholesaler, and restaurants/hotels. The perennials aren't such a big deal since we don't re-plant each year, but the annuals are our biggest sellers, so we have to transplant a lot each year. Since we're a small operation, I can't hire laborers and I'm looking to save myself lots of time and backaches by using a transplanter!
/ tractor speed #9
Tony, it looks like somebody has to ride that thing facing backwards. Your wife's really going to love that.
/ tractor speed
/w3tcompact/icons/grin.gif it's good for me that she grew up working in tobacco fields; otherwise, I doubt she'd go for it! I've offered to let her drive the tractor, but she'd rather ride and set plants--at least she isn't opposed to the idea of a new toy--maybe her back aches a little too!
We actually have access to an old tobacco planter, a two-seater, but it's too big for my little Yanmar.
Attached is another picture of the small transplanter with some of the available options.
tony w
/ tractor speed
oops, let me try that attachment again! /w3tcompact/icons/blush.gif
/ tractor speed #12
I think I've seen something like this on Yanmar's Japanese web site. I believe they use them for planting their rice fields. They have some pretty interesting specialized equipment on their site.
/ tractor speed #13
Tony,
I talked to some friends who run tree farms (evergreens) who use planters like the one you are considering. Basically the speed limitation has to do with how quickly you can pick up the plant and get it into the planter, and how close you want them planted. If your wife can get them into the planter fast enough, you can go faster than the 0.2mph. Also, if you can drive the tractor across the garden at idle (800rpm) without stalling, then that works out OK.
Some of the larger Yanmars have creeper gears which would be perfect for your application. Unfortunately, the YM1401 doesn't have the creeper gear.
Greg
/ tractor speed
Greg,
Thanks for the info. I'll just have to "train" my wife to work quickly!/w3tcompact/icons/grin.gif
I suppose .2 mph would be slow enough if we were spacing our plants 12-18" apart?
Do your friends own a Holland brand transplanter? If so, have they been pleased?
Thanks a lot!!
Tony w
2017 NISSAN NV2500 4x2 VAN (A59911)
2017 NISSAN NV2500...
PALLET OF MISC PARTS (A63291)
PALLET OF MISC...
(5) 22.5 TRUCK TIRES (A63291)
(5) 22.5 TRUCK...
YANMAR VIO35-6A EXCAVATOR (A63276)
YANMAR VIO35-6A...
GRAVITY WAGON (A63291)
2023 Unverferth 3PT 6 FT Perfecta Field Cultivator (A63688)
2023 Unverferth...
