TRACTOR SHOPPING
/ TRACTOR SHOPPING #1
cliff marsh
kioti DK
WHAT IS A POWER SHUTTLE AND A SYNCRO SHUTTLE TRANSMISSION
/ TRACTOR SHOPPING #3
Welcome to TBN!
The main difference between a Syncro Shuttle and a Power Shuttle is that you do not need to use the clutch when changing from foward to reverse when using a Power Shuttle. When using a Syncro Shuttle the clutch is needed every time.
Power Shuttle will normally have more gears also.
/ TRACTOR SHOPPING #5
I'll use my tractor as an example. My transmission has a main shift with 4 synchronized gears, a high / low range shift, a shuttle shift, and a clutch pedal. The 4 main gears with the high and low range gives 8 different speeds or gear ratios. The shuttle has three positions; forward, neutral, and reverse. So, I use the main shift and the range shift to select one of 8 speeds and then set the shuttle to forward, neutral, or reverse.
OK, because I have 4 synchronized gears in the main shift I can shift between these 4 gears while the tractor is moving, using the clutch pedal. I cannot however shift between high and low range while the tractor is moving because those gears are not synchronized on my tractor.
With a synchronous shuttle you use the clutch and change the shuttle position, while moving if you like.
My tractor has something called a hydraulic shuttle, it uses a wet clutch. If I want I can change the shuttle position without clutching. This is especially nice when doing a lot of repetitive forward/reverse loader work. The wet clutch is also supposedly more durable and smoother to operate than a dry clutch.
This might be what you are referring to as a power shuttle, although there is also something called power shift, where one can change speeds/gear ratios without clutching.
Which tractor model/setup are you considering?
2020 WIRTGEN WR200 XLI SOIL STABILIZER (A62129)
2020 WIRTGEN WR200...
211453 (A62131)
211453 (A62131)
Yamaha Golf Cart (A57149)
Yamaha Golf Cart...
Colombo Twin Master (A64119)
Colombo Twin...
2007 CHEVROLET 3500 DUALLY 4X4 DIESEL TRUCK (A59575)
2007 CHEVROLET...
2022 EZ-GO ELITE...
