Tractor rim capstan winch??
/ Tractor rim capstan winch?? #21
Here is a couple of pictures of the one I built.
David from jax
/ Tractor rim capstan winch?? #22
I wasn't going to post today, but it's my 1 year anniversary of the delivery of my tractor (see siggie)! :cool: :D
@ Egon:
So with the snatch block, uh, I'll confess ignorance. Obviously I wrap rope or cable around it, then I can take my choice of lowering from above or pulling from below (mechanical advantage of 2 on the force). But then, what do I pull with? I have a 1500/3000 lb hand operated racheting rope haul, but I was trying to figure a way to use 18 hp of diesel (or 14 at the PTO) to save me'poor arms!
So I'm still faced with reeling a cable in & out with some type of tractor-mounted winch, or just hooking up the cable in some fashion and driving the tractor the necessary distance - or are you saying that the snatch block could also be anchored and used to change the direction of rope travel as I need to make the pull? That'd make sense, I may just have answered my own question! :eek:
Anyway, I've enjoyed my sporadic first year of posting, and my first year of sporadic tractor usage, and look forward to many more (and more frequent seat time)!
/ Tractor rim capstan winch?? #23
Technically speaking,a snatch block is just a block with one side that can be opened so the rope can be placed on the sheave without threading it from the end of the rope. Like this.
Here is a nice page that explains the various methods to achieve mechanical advantage using pulleys.
SUMMERLIFT - Pulley Basics
And a pretty picture....
If you happen to get around any sailors...pronounce it "taycul" and they might buy you a drink.
/ Tractor rim capstan winch?? #25
Thanks, both of you. I knew that the snatch block was essentially a pulley, but that opening feature is the best!
<trundles off to TS or HF or HD or Lowes or something...>
Keller 16ft Folding Ladder (A65579)
Keller 16ft...
2024 Wolverine X2 1000 R-Spec (A62679)
2024 Wolverine X2...
John Deere 530 MoCo (A66408)
John Deere 530...
0.75yd. Concrete Bucket (A65640)
0.75yd. Concrete...
New/Unused 72in No Till Seed Drill (A65583)
New/Unused 72in No...
2013 DRAGON  130BBL VACUUM TRAILER (A65643)
2013 DRAGON...
