Tractor recomendations and /or critiques
/ Tractor recomendations and /or critiques #1
SnappyBob
Floresville, Texas
It's time to replace the old tractor. She's all wore out and just doesn't fit the bill feature wise anymore. I need to buy a tractor that can haul round bales from the front or rear and also have a front end loader capability. I want a full size tractor frame and somewhere around 50 HP. I've always found sites like this to be very educational when I am in need of buying big ticket items. So, does anybody have any anecdote's, praise or condemnations on anything that has been recently bought? Thanks in advance for any responses.
/ Tractor recomendations and /or critiques #2
The M5040 model comes to mind beings you want a full sized tractor. I own the L5240HST and am very pleased with for an all round tractor but I believe it is considered to be in the utility class :confused: The scut, cut, utility stuff confuses me at times..
I am sure more folks much more savy with this class of tractors will chime in.
And welcome to TBN.. Great place full of info. and friendly folks..
Chuck.
/ Tractor recomendations and /or critiques #3
Take a look at the Mahindra 6030 if you have a nearby dealer. It looks like you are near San Antonio and Bill's Tractor is located there. He is one of the largest dealers in the US.
The 30 series is an updated version of the 00 series. I have an 06 6000 4x4 and have not found a job it can't handle. The bale handling is a snap. When I feed cattle I usually have a bale on the front and one on the 3 pt. hitch unroller.
Also baled over 600 4x4 bales this summer with the tractor.
/ Tractor recomendations and /or critiques #4
My new Mahindra 5525 (54 hp engine, 45 hp pto, 2WD, ML250 FEL with 6-ft bucket) can lift 2950 lb on the FEL and 3525 lb on the 3pt at the lift arm pins. The tractor weighs 5370 lb without the FEL. Price: around $17K with FEL. Add $800 for skid steer type FEL quick attach and $750 for triple remotes. The 5525 has a basic constant partial mesh gear tranny, nothing fancy, just a big, heavy red tractor.
/ Tractor recomendations and /or critiques #5
Welcome to the forum and good luck with your new tractor quest.
Don
/ Tractor recomendations and /or critiques #6
I have a Montana 5740 with Cab and FEL and 4wd. It's 57HP mitsibishi engine 52 hp pto. I really like mine. I got a dealer demo with 60 hrs for 26k. There are really a lot of good tractors out there. What dealers do you have nearby? Just make sure you go ride a bunch. Talk to farmers nearby and get pros/cons.
Good Luck
/ Tractor recomendations and /or critiques #7
+1 for the Mahindra 6000...See if Bill has a "leftover" 6000 that he'll part with reasonably (ie. more reasonably than a 6030).. Shuttle shift, fully syncho trans, strong, heavy basic full size utility unit...you can also get a BH that bolts right up if you have a need for such a thing...BobG in VA
/ Tractor recomendations and /or critiques #8
Welcome to TBN. I purchased a JD 5203 last year and it is an excellent tractor. It is a basic utility tractor but it has the qualities that you require. It is manufactured in India but don't let that hold you back it still has a John Deere warranty.
/ Tractor recomendations and /or critiques #9
IMHO, the best buys available these days are either the 5XX3 series Deere's while they last, or the 500 series Massey Fergusons. Lots of bang for the buck with either. Really good tractors at that! I've got a pair of 583 Masseys that have seen far more use in a year than the average user puts on one in 5 or more years. Not the first single issue.
/ Tractor recomendations and /or critiques #10
SnappyBob: welcome to the forum. Are there any features in particular that you were interested in?
FWJ: I've seen you recommend those Massey 583's a few times now, they must be pretty good. Just wondering which transmissions you went with?. The 583's look nice, however I've driven a couple of tractors with the hydraulic/power shuttles and I don't know if I'd want to go with the standard mechanical clutch at this point.
Thanks for all of the replies. Feature wise we are looking for round bale moving capabilities front and rear for the cattle operation and FEL for mixing soils, compost management etc. Our property is in a very sandy area so we need to make sure whatever we get can handle sandy situations in overly wet or overly dry conditions. The old Alice Chalmers that we are replacing was used primarily for pulling hay wagons, round bale buggies and fertilizing pastures among other odd jobs. We never had to worry about the extra weight hanging on the front and/or back. We have been told that the narrow tires on the Mahindra might be a problem in the sand with extra weight on the front. Also rear wheel traction may be a problem in that situation so we are wanting to investigate all of the 4WD, RWD, All wheel drive, front assist drive etc. etc. etc. Right now we have a no wheel drive. We don't want to buy too much tractor but we certainly don't want to wind up with not enough tractor that's going to be more aggravation than it's worth. That's why I turn to you guys. You are out there using the products being offered in todays market. If you like them tell me about it. If you don't, tell me that too. Again, thanks for your replies.
/ Tractor recomendations and /or critiques #12
Thanks for all of the replies. .... We have been told that the narrow tires on the Mahindra might be a problem in the sand with extra weight on the front. Also rear wheel traction may be a problem in that situation so we are wanting to investigate all of the 4WD, RWD, All wheel drive, front assist drive etc. etc. etc....
??The Mahindra that we are speaking off has 11.2 X 24 fronts and 16.9 X 28 rears..If you want/need an FEL you need to fill the rears on ANY unit you pick up...Again, "narrow tires"??
As far as any decision you make, you didn't give a round number as to your budget...unless thats not an issue for you....BobG in VA
/ Tractor recomendations and /or critiques #13
I'll cast my vote for the John Deere 5003 series as well as the 500 series Massey Ferguson's. there's a good selection of tractors from all makes in this class though, so take the time and do your homework, drive all of them you can, kick the tires, ask questions, etc.
I can't speak for other makes of tractors in this class but I can speak on the John Deere 5003 series as I bought a brand new 5203(56 engine hp and 47 pto hp) with MFWD a few months ago. in 2007-2008 these models were upgraded with features such as MFWD, single rear remote, syncshuttle and syncreverser transmission(depending if you bought 2wd or 4wd), and all have turbo. I paid $19,500 for mine and also got 0% for 48months, awesome price for my trade-in ($1,000 less then the price of the tractor the day it was bought new in 1978). when all added up i just couldn't say no to the deal even though i wasn't planning o buying a tractor at the time. anyways, I was hesitant about the whole made in India thing but from research i learned that alot of people are being misslead. these tractors are made in India, BUT it's not like they're being contracted out by some other manufacturer, John Deere themselves are building these machines in a brand new plant in India. go look at one up close, you will see the quality in them. so rule the India thing out. they also come with a Dana front axle in the MFWD models and a Cararro axle in the 2wd version.
As for the Massey Ferguson, well the ONLY thing that made me not go with them was one simple reason. no dealer closer then 45 min to my farm. the JD is 15 min away. that was the only issue i could not get over. had there been a MF dealer closer, i would have bought a MF 543 or a 563. i was sold on them from the moment i sat on one and drove it around. VERY comfortable tractors!
/ Tractor recomendations and /or critiques #14
Well SnappyBob I see you found us from the tool shed at Gardenweb. Welcome. I don't know much about that size of tractor but I think if you are going to do much loader work a 4X4 is in order. Don't forget to have the dealer weld on some hooks on the top of the loader for chains. If you don't have them eventually you'll wish you did. There's always something that needs to be picked up and put in the bed of your pickup. They also make pulling old fence posts a breeze. I bought my tractor used from a guy that advertised it in the Little Nickle want adds. You probably have a similar want add paper in your area. Craigslist also has some tractors in there too if you are getting sticker shock from a new tractor. Your might want to look at Tractorhouse.com too. You'll have to be very handy with a wrench if you get a used one. On my tractor if there was a weak design flaw that part failed. Some of the parts were covered under warranty. I saved about $10,000 compared to a new tractor. I can turn a wrench for a long time for $10,000. You probably won't save very much when it comes to a used JD, Kubota or NH since they hold their value so well. If you do decide to go with a new tractor like I said over at the Tool Shed the dealer is more important then the tractor brand except for maybe Chinese tractors. Also, there is a good search function on this site that you can while away the hours with.
/ Tractor recomendations and /or critiques #15
I checked your profile but couldn't find any info.. so...
What tractor are you replacing?
what's your land like?
what other tasks will it need to do?
soundguy
/ Tractor recomendations and /or critiques #16
I'll go along with the 5xxx series and you can add the extra wide tires 16.9 (I think) for just a little more on the price tag. They have a very strong FEL, 3pt is smooth and the operators station is laid out well. I've got the 5103 with the shuttle shift and have fount it to be very easy to use and the clutch isn't as hard as I've seen on others. HST is good but I found that the amount of FEL work or bale moving didn't justify the added cost.
/ Tractor recomendations and /or critiques #17
I have a 52HP tractor and if I were going to do it over again I would get a 60 HP or maybe even 40 HP. Seems like implements are made for 40 or 60 HP but not 50 HP. Just my observation. I strongly feel you would need a 4 cylinder engine!!!! 60 HP or higher. Happy shopping!!
/ Tractor recomendations and /or critiques #18
I guess I don't undestand your issue. I have a 56 HP 5203 JD and I can utilize a Cat I or II implement without a problem. The 3 cylinder engine seems powerful enough to do the jobs that I require. I must be missing something??? :confused:
So many choices and they all have their good features. This would be so much easier if I could just go ahead and buy about three tractors.:rolleyes: This time of year it's hard to do much actual tractor shopping. We all work full time and with Christmas, deer season and weekend chores that need to be done in daylight visits to tractor dealerships are hard to schedule. After the first of the year we will be able to hit it hard. I'm just thankful for the internet and sites like this to allow me to do my homework much more effectivley. From what I've heard so far, I'm leaning toward 4WD. I can't commit to a brand yet. I think that will take some saddle time.:)
/ Tractor recomendations and /or critiques #20
Do a bunch of test driving before you make your choice. talk tot he dealer as well.. he will be doing your warranty work..
soundguy
