Tractor quits after warm
/ Tractor quits after warm #1
bluetick2
Ford3600
Ford 3600 quits after warms up, not the coil, so will the condenser do this? I thought they just blow and done, cracked cap? TIA
/ Tractor quits after warm #2
I've no idea how you know it's not the coil but yes, it could be the condenser. If you have one it could also be the ballast resistor and you are correct, it could be the distributor cap. It could also be the rotor failing to make contact with the center of the distributor cap. Of course it could be the ignition switch as well or loose or corroded contacts on the wiring. Perhaps something is moving a bit and shorting to ground. The actual troubleshooting is up to you.
/ Tractor quits after warm #3
I've heard of condensors shorting when they get hot. But I've never actually seen it happen. If it does, the spark will either completely disappear or become weak and feeble at the points, coil. & plugs.
More likely to be old plug wires, connectors, & dist. cap.
Test the coil by connecting the secondary to a spark plug and holding the plug against the frame while touching the coil primary connections to battery voltage.
Johnson 3pt 12' High Speed Disc Harrow (A64119)
Johnson 3pt 12'...
12in. Tooth Excavator Bucket (A64194)
12in. Tooth...
2012 Ford Explorer SUV (A61574)
2012 Ford Explorer...
2009 Sterling Acterra Altec DM47TR Insulated Digger Derrick Truck (A60460)
2009 Sterling...
2019 WABASH DVLSHPC 53X102 T/A DRY VAN TRAILER (A59912)
2019 WABASH...
2018 PJ Trailers 14ft T/A End Dump Trailer (A61573)
2018 PJ Trailers...
