Tractor quits after warm
/ Tractor quits after warm #1
bluetick2
Ford3600
Ford 3600 quits after warms up, not the coil, so will the condenser do this? I thought they just blow and done, cracked cap? TIA
/ Tractor quits after warm #2
I've no idea how you know it's not the coil but yes, it could be the condenser. If you have one it could also be the ballast resistor and you are correct, it could be the distributor cap. It could also be the rotor failing to make contact with the center of the distributor cap. Of course it could be the ignition switch as well or loose or corroded contacts on the wiring. Perhaps something is moving a bit and shorting to ground. The actual troubleshooting is up to you.
/ Tractor quits after warm #3
I've heard of condensors shorting when they get hot. But I've never actually seen it happen. If it does, the spark will either completely disappear or become weak and feeble at the points, coil. & plugs.
More likely to be old plug wires, connectors, & dist. cap.
Test the coil by connecting the secondary to a spark plug and holding the plug against the frame while touching the coil primary connections to battery voltage.
2020 MACK ANTHEM 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2020 MACK ANTHEM...
2014 Ford Transit Connect Passenger Van (A61573)
2014 Ford Transit...
2009 International 4300 Bucket Truck 55' (A62613)
2009 International...
2018 MACK CHU613 (INOPERABLE) (A58214)
2018 MACK CHU613...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2005 Freightliner Tropi-cal T396 39ft. Class A Motorhome (A61574)
2005 Freightliner...
