Tractor quit and won't start
   / Tractor quit and won't start #1
BakoJ
2021 LS MT2 25S
I have a MT2 25S that I've had for a couple of weeks. I'm on it most days. I spent about 2 hours on it yesterday, everything went well. I dug out a really large concrete collar with the backhoe and that was a ton of fun.
Today, we were going to lift the collar with the backhoe onto the trailer. The collar weighs somewhere between 400 to 500 lbs. We backed up the tractor and we were about to strap it up when the tractor just stalled. When I turned the key to restart it, the tractor wouldn't start. I can hear the starter solenoid click, but it won't crank. Strangely, the display has going blank. At first, it would light up but the display was blank. After a few tries of cranking, the display doesn't even light up anymore. The headlights, tail lights and flashers all still work.
After opening the hood, checking battery connections and looking underneath, there's a small puddle of what I'm guessing is hydraulic fluid underneath the tractor.
Could this be a fuse issue? I'd be surprised if it was battery. I didn't have any trouble starting it before. I will say, there's a ton of smoke from the engine when I start it up, but it dissipates fairly quickly. I figured that was normal.
   / Tractor quit and won't start #2
RELENTLESSLY check the battery cable connections,, at BOTH ends of the cables.
A voltmeter is useless,, it will show volts, but, a loose connection will lose that voltage when current is pulled.
A loose bolt at where the negative cable connects to the tractor is very common.
Thanks. I'll have to check that in the morning.
   / Tractor quit and won't start #4
Have you attempted to test battery voltage with a volt meter? What about turning lights on? I can already tell you it;s either something minor,something major or a combination of minor and major things but if you put forth a little effort,maybe it won't be neccessary to cover every possability.
I haven't yet. It was getting dark (and really cold!). I will check in the morning, for sure. Headlights, tailights and flashers all work.
   / Tractor quit and won't start #6
Sounds like wiggle pin fell out of wobble shaft or there abouts.
   / Tractor quit and won't start #7
Not familiar with that model, but maybe check for a multi-pin connector to the dash that might have worked loose. That might account for the display and some sort of safety interlock.
Not really sure how that could be related if it's hydro fluid. Unless it's battery fluid from a cracked battery? Also check engine oil ... if low engine could be locked out by a low pressure condition, but that wouldn't make the dash act silly.
Cold starts will choke and shudder and puke. More Glow Plug time should help a lot.
Since your machine is so new, I don't suggest doing a whole lot until you can get ahold of your dealer.
   / Tractor quit and won't start #8
I'm not familiar with your tractor at all and don't know the level of electronics it has but I would say the starting issue and the shutting down issue could very well not be related. For me, I'm always concerned when a diesel tractor shuts down for no reason. That's usually not good and it's a pretty good sign it's not gonna start back up. However i would think it would turn over. My recommendation is get it to the dealer unless you have a service manual and a good knowledge of working on tractors.
   / Tractor quit and won't start #9
I have one i bought new a year ago. The glow plug timer is short. Apparently its a high current plug and heats rapidly. The more glow time you have the easier it is to start and the less the partial ignition causing the white smoke on startup. I never tried to start mine colder than about 40F. On those days I will watch the glow coil in the dash display come on and go out. As soon as it goes out I cycle the On-Off Switch back to On and repeat a couple of times. Hitting the switch the 3rd time and rolling on over to Start gets a fast clean start.
On the click your starter solenoid is energizing closing the high current contact closing the circuit to spin the starter. There has to be current flowing for the starter to spin. Other folks have clued you in as to what to check. You have an "open circuit" somewhere in your loop from battery + around and through the starter and back to battery -.
Open circuit can be defined as a loose connection that would not allow the battery to supply the 100-200 amperes necessary to spin up the starter, get the bendix to engage the engines flywheel and supply the power to spin such. I agree if you had easy starting, something became loose during your previous run and the battery and charge level is probably not the problem.....but it could be if it was accidentally discharged (somehow) while you were working.
   / Tractor quit and won't start #10
I also have MT225S yes it hates cold weather. Noted on this board if you cycle glow plugs it will start better. I am in agreement but it still puffs a lot raw diesel for 30-40 seconds until motor is running smoothly in cold weather. Check your safety switches they can prevent motor from turning over. The MT225S is drive by wire throttle. Checking fuses and grounds is also wise suggestion. I have over 250 hours on my tractor it has been used primarily as yard mower with attached MMM. Only complaint I have is the plastic wheels on the MMM. Poor design on all four wheels. I have re-engineered the wheels adding swivel bearings and oil lite bronze bushing. The MMM does fantastic job mowing no disappointments running gear was poor design, cheaply designed.
Gator Utility Cart (A49346)
Gator Utility Cart...
40ft High Cube Shipping Container (A48837)
40ft High Cube...
New/Unused 10ft 30 Drawer Stainless Steel Workbench (A48837)
New/Unused 10ft 30...
UNUSED LANDHONOR ARTICULATING BRUSH CUTTER (A50460)
UNUSED LANDHONOR...
2018 Toyota 4Runner SUV (A48082)
2018 Toyota...
2006 Dodge Dakota 4x4 Crew Cab Pickup Truck (A48081)
2006 Dodge Dakota...
