Buying Advice Tractor Purchase Advice
/ Tractor Purchase Advice #1
JeffInCO
Bronze Member
Northern Colorado
1952 Ferguson TO-30
I'm thinking that it's time to buy a tractor. So far, I'm really impressed by the Kubotas, so I figured I'd post here.
We're on 20 acres in Northern Colorado. Our acres are mostly native grass pasture. The land is mostly flat with some gently sloping hills except on the east end where there is a steeper hill with an irrigation ditch running across it. We have 5 nice rows of trees/shrubs to make a windbreak on the north and west of the house.
We plan to eventually do some small-scale organic farming. We have a pond to maintain (about one acre). We have water rights that were not used by the previous owner, so irrigation ditches enter and leave our land on both the west and east but there are no trenches on our land to bring the water from the ditches to where it might be needed. Nor are there trenches to properly carry runoff, and there are a few areas that get a bit swampy when it rains. Finally, we're planning a remodel of the house and I'd like to do some of the dirt moving/trenching for utilities/etc.
We currently have a 1952 Ferguson TO30 -- very similar to a Ford 2N/8N. It's a good little tractor and I plan to keep it even if we buy something new, but it needs some repairs and its capabilities are limited. We have a 5-foot mower, a cultivator, a blade, a 3-point-mounted scoop, and a few other minor odds and ends for attachments.
I would like to add a tractor that can do all of the following:
1) Front-end-loader work (pond maintenance, other work)
2) Ditching (various ways to do this)
3) Backhoe
4) Eventually, plowing/cultivating
5) Clearing snow in the winter (maybe just the FEL, maybe a blower in the future?)
I was thinking about going with a 5740 with an HST, but after reading here I'm wondering if this would be a good setup for #4 due to the HST. At the same time, my understanding is that the HST is great for loader work. Maybe I should get something smaller now (probably a Grand L40 in the 30 or 40 HP range) and rely on the TO30 for ground-engaging work until I decide I need something with more power.
I'm not real sure about the best way to do the ditching either. I've heard suggestions that a blade might do the trick; obviously a backhoe could do it (I have a good 500 feet of ditch to pull from the road to our pasture). I know there are PTO-driven ditchers out there, but 50 PTO horses seem to be on the low end for those.
I'd appreciate your thoughts and comments!
Thanks,
Jeff
/ Tractor Purchase Advice #2
Jeff, the hydro's will outwork any gear drive tractor for both loader or PTO work. The flexibility of the speed is the main reason and the 5740 would be a great tractor depending on what you might choose to do.
The five foot hog is small for a 50 horsepower tractor so that might need to be changed out unless you choose to suffer.
I did recently went between a 5740 and a 6040 and the fellow took the M-series.
/ Tractor Purchase Advice #3
I would think your concerns about HST and item #4 could be mitagated by the speed control on the tractor. I have a L4400HST and the speed control unit does a nice job of giving you a constant speed.
/ Tractor Purchase Advice #4
If you're leaning towards the 5740, you probably shouldn't consider going smaller, as you will pretty quickly end up wanting bigger. So long as the 5740 can handle the plowing chores, then that sounds like the right machine for you.
And as Mike stated, the speed control on the HST would be perfect for plowing long straight runs. You will love the HST. I do, and I started on gear drive tractors - now, I don't think I'd ever go back to gear drive in a newer machine.
The backhoe will tackle the ditching tasks, along with a miriad of additional around-the-farm tasks that you probably can't even dream up right now, but will once you have it.
Also, if you are open to buying out of state, PM me and I'll give you some advice. I can also give you some advice on some of the in-state Kubota dealers that handle your area.
/ Tractor Purchase Advice #5
No. 4 relation to hp and gears is related to soil type. If you have loam, sandy loam, or even clay, a big enough tractor will plow it, regardless of HST or geared trannie. If you have an ancient, never previously plowed true hardpan (caliche, ironpan, duripan, etc. fragipan, clay packed by heavy vehicle traffic, is not a true hardpan) however, you need something with big rear wheels, good hp, geared trannie with super low ratio pulling gear, and ballast. If you have shallow soil and actual rock beneath that, you need more than a tractor and plow, maybe a downpressured auger with rock fracturing bit (Pengo) and some explosives (you can get away with a lot in really rural areas of CO).
Soil conditions can vary greatly from one little spot to the next and also by vertical horizon layers. What is your soil profile?
http://www.pengoattachments.com/product_category.aspx?ID=1
/ Tractor Purchase Advice #6
Sounds like a lot of trench work if you are going to farm with the available irrigation. May want to look at the Kubota commercial TLB's.
MarkV
/ Tractor Purchase Advice #7
The M6040 would be my choice.
/ Tractor Purchase Advice #8
I'm with George on this - the M6040 would be my choice too.
Knowing what I know, I would first scour the earth for an L5450 with hydraulic shuttle and the original Bradco 11-foot backhoe - but they are very hard to find unless they have a lot of hours. The M6040 is the closet thing to it in power and weight these days. An L48 would be good too, but they are on R4 rubber and for plowing you'll get better traction with R1's. Also, the L48's loader is not removable.
/ Tractor Purchase Advice #9
I am also thinking about a first time purchase of a new kubota. Since this the first time through for me, do you negotiate the price the same way as a car purchase? Are the dealers willing to deal to the same degree. They all seem willing to give you quotes via email or phone but the prices see inflated. Is it better to hit the dealers in person? Looking for any advice anyone might have.
/ Tractor Purchase Advice #10
I don't think I haggled that much but I did shop around and when talking with a dealer I did let him know if other dealers had a lower price. Of course I knew, and the dealer knew, and you know that the lowest price is not the only consideration.
I'd go to the dealer in person, that way they know you've moved past the initial shopping phase. Tell them that you are looking for the lowest price they can give you and that you are shopping around. Use that time to get a feel for the dealer and his facilities and take that into consideration. With that info out in the open, both you and the dealer know what the score is and can make good decisions. And if he knows that you are shopping around, his low price should be his real low price and haggling over it probably won't be necessary.
I was fortunate, the dealer with the lowest price was the dealer I was most impressed with and the closest by.
/ Tractor Purchase Advice #11
I think N80 gave some good advice. Tractor sales are not the same as the auto sale game from my experience. That is not to say that you should not shop around. There also seems to be a fair amount difference between the "going price", depending upon region.
MarkV
/ Tractor Purchase Advice #12
The regional price thing is true. When I was at a dealer in Hendersonville, NC he told me he had a guy driving down from Conn. to buy a new tractor because the prices were better here and a TBN member from Virginia bought a tractor from the local dealer here because of better prices.
Our land has been farmed before, but it's probably been most of 40 years. I think I've heard from the previous owner and neighbors that at least corn and oats were grown. But for the last 40 years it's been just native grass.
I don't yet have a soils test.
I know the "M" series is built a bit stronger, and with more horsepower. A few questions:
1) It doesn't appear that Kubota offers a loader as a standard option for the M6040. What would you suggest for the loader?
2) What is the difference between the synchro and hydraulic shuttle shift? I guess the hydraulic is only available with a cab (not sure I need or want a cab anyway).
3) What do you see as the primary reason to go with the M6040 over the L5740? Plowing or ditching? HST vs Gears? Overall durability?
As I said in my original email, I'm wondering if one "compromise" tractor is the wrong solution. Maybe I should go with something smaller (Grand L) for front end loader and backhoe work, then eventually buy a used higher horsepower tractor without all the bells and whistles for farming.
The 5740 looked like it might be a good compromise between the two. Maybe the 6040 is a better compromise?
Thanks for your input!
Jeff
/ Tractor Purchase Advice #15
JeffInCO:
1) Kubota offers the LA1153 FEL as a standard option for the M6040, it's very nice, comes with the quick attach skid steer mounting system. The specs for the loader are:
AttachmentView
2) Synchro shuttle vs. hydraulic shuttle: All of the M5040/M6040/M7040 models come with an F8/R8 shuttle transmission. There is a 4 speed synchronized main shift, and a high/low range which gives you 8 speeds. There is a shuttle shift lever located to the left of the steering wheel. The shuttle let's you go between reverse/neutral/forward. The synchro shuttle has a dry mechanical clutch, so you push in the clutch pedal when using the shuttle to change directions. The hydraulic shuttle is available on 4wd models ROPS or cab, it has a wet hydraulic clutch pack that is smooth and durable. With the hydraulic shuttle you just move the shuttle lever between reverse/neutral/forward to change direction without using the clutch. Try the hydraulic shuttle, I think you will like it!
3) For me and my needs the M6040 is a better tractor than the L5740. I would only consider the 5740 if I needed the HST transmission. The 6040 is bigger, more powerful, stronger loader, more lift, etc.
I cannot really help with the compromise question or your tractor buying strategy. There is no correct answer, if you visit three different dealers they will give you three different suggestions. Good luck, keep posting and asking questions :)
bad boy zero turn 72 (A56859)
bad boy zero turn...
Toyota 7FGCU25 5,000 LB Cushion Tire Forklift (A59228)
Toyota 7FGCU25...
2025 Kivel 48in. Forks and Frame Skid Steer Attachment (A59228)
2025 Kivel 48in...
Pick up Bed (A60352)
CAT 930M (A58214)
CAT 930M (A58214)
UNUSED FUTURE HYD HEDGE TRIMMER (A52706)
UNUSED FUTURE HYD...
