Tractor on 4x8 trailer
/ Tractor on 4x8 trailer #21
I think it's important to distinguish exactly the type of equipment is being towed and the circumstances under which it needs to be towed. I would agree that a BX23 with BH and FEL is too much for the small trailer, but a 2230 without those implements is most likely fine -- given the correct tongue weight and driving characteristics. For me, I'll be towing my BX2350 on a similar trailer (Car-mate 5x8, rated for 2990lbs) without a BH and perhaps only occasionally with the FEL -- and only on an infrequent basis. In that case, it will be just fine. It's just not practical for many people to own a tandem axle 16' trailer. For much longer distances, or if I was transporting the machine on a daily basis, I would certainly rent or buy a larger trailer.
The important thing is to not exceed the rated capacities for the trailer or the tow vehicle and to recognize when it's better or more practical to utilize more substantial tow equipment.
Just my $.02.
I actually took my trailer by a trailer manufacturer and had them look at it while I was there to get some ramps. From a weight standpoint, they said it would easily do it since I was at about 1/2 the rated weight. He said people haul 2 or 3 heavy ATVs on his single axle trailers all the time without incident. Then he looked at how the trailer was made and said that the square beam construction also added to its strength. Yes of course he agreed that a bigger trailer would be "better" but that is relative.
I consider myself a rather safe person who does not like to take risks. But that does not keep me from driving my Jeep Wrangler at 75mph on the freeway from time to time. If one front tire were to blow out, it could flip me over. I realize this is similar for single axle trailers.
If I were hauling this tractor all over Houston or Seattle etc, I would not be using the smallest trailer possible. I'll have to snap a picture the next time I am driving up at my remote cabin and fording that creek with the steep banks so you can see the reasoning for my decision.
If anyone has a better idea if how I can get my tractor back there, I would be all ears. Leaving it home is not an option. I have too much road work and maintenance to do up there.
Regards,
James
/ Tractor on 4x8 trailer #23
fabrej said:
I thought I would share how I transport my Kubota BX2230. I have a 3500# axle trailer and it is rated to carry 2990#. I figure the tractor and loader weight in at about 1700# so I have some extra capacity on it. It does not cause problems turning rather sharp corners with the loader on the trailer tongue and the whole package pulls real easy at 55mph.
James
My BX23 is 2467 or with out the BH 1867
/ Tractor on 4x8 trailer #24
nh_bota said:
I think it's important to distinguish exactly the type of equipment is being towed and the circumstances under which it needs to be towed. I would agree that a BX23 with BH and FEL is too much for the small trailer.
fabrej figures the tractor and loader weight in at about 1700#
The BX23 is only about 600 pounds more.
The only place I might want to tow it would be 3 miles to the dealer it the need should arise.
/ Tractor on 4x8 trailer #25
LBrown59 said:
NOPE
Nope just pointing out this thread is in conflict with all the other threads on the subject.
I also have an 8 foot long trailer that's 6 feet wide .
I have never attempted to haul my BX 23 on it because everything in those other trreads advises against it.
When you read dozzens of post saying not to do it in the other threads but only a few post in this one seggesting it , it makes me wonder just what is going on.
The size of the bed doesn't matter, it's how well the trailer is built. While I don't care much for single axle trailers, I have used them. I have, in the past, used a 6'x10' single axle tilt trailer much like the trailer the tractor is on. It is a well built trailer, and it handles about 200-250lbs less than capacity, very well. If you question your trailers ability to haul near it's capacity, do some "window shopping". Go look at the same type of trailer other companies make. If it looks as strong as the others, or stronger, it should be good. If it doesn't look as strong, I would question it's abilities, and maybe look at trading it in for one of the stronger looking trailers.
/ Tractor on 4x8 trailer #26
It would also be better if fabrej had an 18 wheeler with a flatbed trailer?!?!?
As long as he is within weight limits it looks fine to me. Fabrej seems well aware of his circumstances and capabilities.
/ Tractor on 4x8 trailer #27
From my owners manuel bx23: TRACTOR -1520
LOADER-W/O BUCKET 430
LOADER BUCKET 132
hoE W/O BUCKET-578
MY HOE BUCKET[10INCH]-37
total weght according to my manual 2697 not 2467.
add on diesal fuel,and my loaded tires mine tops 3000 lbs[without the toolbox,cabroof,thumbetc]
I would just like to say im glad your trailer is working out for you .It is probably capable to get the job done.Myself id prefer a tandem,only because if you blow a tire at 55 even with the weight of your tractor,you are gonna have one harry ride to keep it under control.I personally wouldnt risk a 15000 dollar tractor[mine] for an extra grand to pick up a good used tandem[or two for new]Good luck,and everone has their opinion so lets not shout[large writing] at each other,we are all tractor friends here.
ALAN
I would love to have a tandum trailer for my tractor - if they were small enough that I could get one back in to my remote mountain property.
I have the tractor insured.
/ Tractor on 4x8 trailer #29
HELLO AGAIN
Can you give me a little help with that insurance,i may want some for myself. You see i checked into it and my ALLSTATE co said it was not covered on my auto plan if i lost it off in an accident .Even though my trailer itself was covered,the items i was hauling was not.They also said my homeowners didnt cover it when trailering off my property[if i added it:extra fee] So what i was left with is exspensive commercial insurance,in which i cant justify a few grand for a couple trailerings a year.This also made me refuse any tractor "favors" that i cant drive to.This is my reason for buying a safe new tandem,brake controller ,4 chains and binders, and a weight distribution hitch,which was about the same as the insurance fee they wanted.This was my insurance policy.
So if it aint to much to ask ,can you give me the scoop,on cheap trailering insurance on my tractor?
I here what your saying about ,not having enough room ,i had to widen out a few of my roads to accomadate my trailer.Did i understand your towing with a wrangler? I use a cherokee,that straight 6 has more than enough power ,dont need an 8 cylinder,even in hilly areas.
ALAN
No to towing with the Wrangler. I was just trying to make a point about tire blowout dangers and risk. I tow the tractor with my V8 Silverado.
I had Farmers and they wanted to insure the tractor like a vehicle. No thank you - that was expensive. I ended up switching over to Allstate. They have a yard and garden type policy that you can add to your homeowners insurance (in Idaho - not sure about your state). It costs me about $50 per year and coveres the tractor from theft, fire and other stuff at my house. He said that the tractor would be covered on the trailer if I haul it up to my property to mow etc or if I was to haul it to the dealer for service etc. Make sure you get it in writing.
/ Tractor on 4x8 trailer #31
escavader said:
\HELLO AGAIN
Can you give me a little help with that insurance,i may want some for myself. You see i checked into it and my ALLSTATE co said it was not covered on my auto plan if i lost it off in an accident .Even though my trailer itself was covered,the items i was hauling was not.They also said my homeowners didnt cover it when trailering off my property.
1*This made me refuse any tractor "favors" that i cant drive to.
2*This was my insurance policy.
ALAN
1*My insurance won't cover my tractor or protect me against libility if it's off my property . Don't matter it i trailer it or drive it.
I just turned down doing a favor for a guy who lives out the road from me because of that.
2*This still wont' protect you against damage to your tractor and libility claims against you while the tractor is off your property.
/ Tractor on 4x8 trailer #32
LBrown59 [COLOR=#ff0000 said:
2*This still wont' protect you against damage to your tractor and libility claims against you while the tractor is off your property.[/COLOR]
HELLO L BROWN 59,
What i meant by this statement ["THIS WAS MY INSURANCE POLICY"]was,that it gave me peace of mind,trying to be as safe as i possibly could.Thats a big 10-4 on the no to doing others work.They had better be a long time close personal friend or relitive for that[and im still gonna try to get out of it[ ha ha]
My allstate company said my auto liability would cover damage to others [only]if it came off the trailer.
FABREG, Thanks for the info,im gonna check with my agent.
ALAN
/ Tractor on 4x8 trailer #33
escavader said:
HELLO L BROWN 59,
1*What i meant by this statement ["THIS WAS MY INSURANCE POLICY"]was,that it gave me peace of mind,trying to be as safe as i possibly could.
2*Thats a big 10-4 on the no to doing others work.They had better be a long time close personal friend or relitive for that[and im still gonna try to get out of it[ ha ha]
ALAN
1*I know what you meant but I just wanted to remind you that there are other risk that this don't cover or protect against.
2*Speakking of this it just dawned on me that I've been exposed to the risk of no insurance on my tractor or liability protection due to the tractor being off my property on several occasions and I was completely unaware of it at the time.
I cleared off the back of my property lasts winter and had to go over on the adorning property about 10 feet to clear my land to my properly line. Had something gone wrong any time I was over on that 10 feet my insurance wouldn't have paid the claim. Same thing when I went over onto my next door neighbors property a couple of times to haul something back he gave me, Same thing happened with my neighbor on the other side when I cleaned up and removed and old dog pen as a free favor to him. I was only working from my property line to 50 feet over on him, I mowed his lawn free about 3 times a couple of summers ago due to his wife's terminal sickness that year.
..>>>All these times I was exposed to no coverage and didn't even realize it.
/ Tractor on 4x8 trailer #36
Since this post got started on insurance I thought I would add an opinion. I have an umbrella policy that covers my cars and my houses. Is really very cheap considering and it covers liability above and beyond my home or auto policy up to a million dollars. With my company it is something like 6.00 per year for a house and 40 per year for an auto. You have to have maximum liability limits on your base insurance but that does not really drive the price of the insurance up that much. All it takes is one vehicle accident or an injury at your home to make you apreciate having the extra insurance
Case 2090 Tractor (A66285)
Case 2090 Tractor...
Tool Bar (A64127)
Tool Bar (A64127)
STIHL HT250 POLE SAW (A64276)
STIHL HT250 POLE...
New Webbing Slings, Polyester, 6:1 & 15" (A62679)
New Webbing...
2010 John Deere 7330 Premium (A64126)
2010 John Deere...
SDlanch SDLGC80 (A60462)
SDlanch SDLGC80...
