Tractor loader for scaffold?
/ Tractor loader for scaffold? #1
npaden
Platinum Member
Lubbock, Texas
2011 LS U5030C
Okay, I've thought about using my new tractor and loader for scaffolding this summer when painting the house.
My plans are to get some of the clamp on pallet forks and make a scaffold setup out of 3/4" plywood and a frame that will use the pallet forks at the widest that they will go on the loader about 5 1/2 feet apart. The platform will be reinforced and have slots for the forks so that the platform can't come off if you put too much weight on one end.
I would move the scaffold into place and use a ladder to get up to the platform once it was in place and the tractor was turned off with the parking brake set.
Would this qualify me for a Darwin award? It really seems pretty safe to me but maybe I'm overlooking something.
I would appreciate any input on this idea.
Thanks, Nathan
These are the type of bucket forks I'm talking about.
They make different lengths up to 46" of useable fork that would allow me to just use a full sheet of plywood and have plenty of work area on the scaffold. I could easily build some 2 x 4 rails to use also for saftey rails and just have a nice platform to work off of.
/ Tractor loader for scaffold? #3
It's been done before. I won't comment on how 'safe' it is. But you can understand that there is nothing to prevent a slow leak down, which may cause havoc with the house siding or whatever. Or there may be a hose break, that will provide a sudden drop. If you are on the scaffolding at the time, who knows how you will end up.
I've done it, but look for ways to avoid it. I've stood in the bucket and removed shingles from the roof, hoping that something bad wouldn't happen and I managed with no problem. I hope I didn't use up all the 'good luck'. /forums/images/graemlins/wink.gif
/ Tractor loader for scaffold? #4
I'm looking now for a thread that showed a setup I want to build. I don't think I'd be happy with the clamp on forks. I have a QA with forks. But the setup I'm trying to find was built for bucket use. These are the only two pictures I have I hope they help.
/ Tractor loader for scaffold? #5
Picture 2
/ Tractor loader for scaffold? #6
My JD TLB 110 has a mechanical lock which can be used to prevent the FEL from lowering in the event of a hydraulic leak or failure.
While this is provided because the only way to get under the hood without climbing around in the bucket is to raise the bucket, it is effective and something similar might make your proposal more sane.
Of course, the JD lock does nothing to prevent curl/uncurl but take a look at the JD system and see what you could adapt. I bet you could provide a safety lock for both actions.
/ Tractor loader for scaffold? #7
here is a link to an OSHA approved forklift work cage.
Keeping in mind that forklifts have no safety systems to prevent dropping the cage, (but you always fall straight down with a forklift), I think you could make something up for your tractor.
/ Tractor loader for scaffold? #9
I don't see a problem with those type of forks. They're designed to lift 1500lbs or more. I doubt you'll even come close to loading them. If you're worried about them slipping off, then rig up some kind of small safety chain that connects you platform to the bucket.
/ Tractor loader for scaffold? #10
To be on the safe side if a pressure hose should brake, you could install safety valves on the cylinders that locks the oil in the cylinders if a hose brakes. With these valves you need oil pressure to get the loader down.
/ Tractor loader for scaffold? #11
I don't think this is a efficient method regardless of safetly. You will be climbing up/down that ladder and moving the tractor so often. If you were going to be working for several hrs servicing a pc of equipment, it would be nice. But for painting, two ladders and a pic board. Pump jacks work well too if you are doing a second storey
Patrick
/ Tractor loader for scaffold? #12
np,
Odd you posted this, because i just got back from my place in TN where i had to enclose an old shed. The thing is 32x15, 14' high on one long side and 18' on the other. I had a 12' ladder, so...when i was stripping some of the ecclectic mismatched siding i had to ladder myself up to the bucket, then pull the ladder up and lean it against the shed wall from inside the bucket. I know it is not a preferred/safest method, but it got the job done. It also got me to thinking about a "man lift" for the bucket because i will be lifting logs to a height of 10' when the house gets under construction.
RD
Steiner 48in Front Loader Tractor Bucket Attachment (A64553)
Steiner 48in Front...
2021 CATERPILLAR 303.5CR EXCAVATOR (A65056)
2021 CATERPILLAR...
WACKER NEUSON  LTN8 LIGHT PLANT (A67714)
WACKER NEUSON...
Ford Tractor (A64911)
2023 Polaris Ranger 4x4 Gas Utility Cart (A66734)
2023 Polaris...
2009 MACK CHU613 (INOPERABLE) (A67714)
2009 MACK CHU613...
