Tractor less
/ Tractor less #1
4playxj
High Springs, FL
Long 360
Hey, been borrowing my neighbors tractor for the last two years. He doesn't use it anymore. It is a Long made in Brashov Romania, a 360 I believe. It is a poorly maintained heap that won't die. It has a bad fuel leak that has recently started on the back side of the injector pump. Looking for ideas, I think it might be the fuel damper.
Oh, and Hello from North Central FL!
/ Tractor less #2
Romanian Long: Soldiering on for the Motherland.
/ Tractor less #4
Welcome from from Putnam County Fl. Hope you find what you need. I know nothing about Long other than I remember hearing (might be complete BS) that they had used older model ford tractors built under license in Romania.
/ Tractor less #6
Superior Tractor, 5353 West Beaver Street (US90), Jacksonville is and or was a Long Agricultural Equipment dealer. I just happened to be driving by. Can't tell if it's still open or not; might be able to goggle them and find an email or phone number.
/ Tractor less
Thanks for all the replies. I found out the injection pump damper/pressure equalizer is leaking at the seam where the top seals to the body on the underside. I found the part online, along with a fuel pump since mine was leaking, and they are ordered. Getting to the equalizer is a bit tricky, I managed to get it out and plug the hole to make sure that was the source of the leak.
2020 MACK PINNACLE (A60736)
2020 MACK PINNACLE...
832742 (A61166)
832742 (A61166)
HYDRAULIC TILTING BUCKET FOR MINI EXCAVATOR (A58214)
HYDRAULIC TILTING...
TOYOTA FORKLIFT (INOPERABLE) (A60736)
TOYOTA FORKLIFT...
2014 FREIGHTLINER CASCADIA (A58214)
2014 FREIGHTLINER...
2023 FORD F-150 (A60736)
2023 FORD F-150...
