Tractor is dead...help
/ Tractor is dead...help
The issue with tractor not starting was indeed the main ground wire. Replaced and it's all better now. Thanks everyone.
/ Tractor is dead...help #22
How to use a VOM:
with this information you can check out your system
willy
/ Tractor is dead...help #23
Glad you got it fixed. Ground issues are a pain in the butt .
/ Tractor is dead...help #24
Also glad you got your tractor running again.
Grounds are always a pain.
/ Tractor is dead...help #25
Great!
Grounds in wet environments are always a good 'first' place to check.
A weak ground can show voltage or continuity but simply can not handle higher amperages.
Clean metal to metal bonding is an absolute must.
/ Tractor is dead...help #27
I have a 2014 new holland boomer 24. When I go to start tractor there is nothing....no lights, no clicking, nothing. Tractor is completely dead. I have bought a new ignition switch and replaced the battery. The wiring harness has juice as we tested that. Dont know what else it could be....someone please HELP....I'm desperate to get this tractor going asap as I need it to feed my horses.
I'm going through the exact same thing with my Jinma 284. Sorry!
/ Tractor is dead...help #28
yo;u guys must have a lot of money just replacing all the parts etc.
and not checking to see what is actually wrong.
Read the other posts about dead tractors.
If all else fails I can loan you my shovel
willy
7002SFL (A61572)
7002SFL (A61572)
2008 PROCO 130BBL (A65643)
2008 PROCO 130BBL...
80003CFL (A61568)
80003CFL (A61568)
Gasoline Concrete Mixer, Honda 8.0 Engine  (A62679)
Gasoline Concrete...
2022 CATERPILLAR 303.5CR EXCAVATOR (A65053)
2022 CATERPILLAR...
New 40' Double side door Container (A62679)
New 40' Double...
