Tractor is dead...help
/ Tractor is dead...help
The issue with tractor not starting was indeed the main ground wire. Replaced and it's all better now. Thanks everyone.
/ Tractor is dead...help #22
How to use a VOM:
with this information you can check out your system
willy
/ Tractor is dead...help #23
Glad you got it fixed. Ground issues are a pain in the butt .
/ Tractor is dead...help #24
Also glad you got your tractor running again.
Grounds are always a pain.
/ Tractor is dead...help #25
Great!
Grounds in wet environments are always a good 'first' place to check.
A weak ground can show voltage or continuity but simply can not handle higher amperages.
Clean metal to metal bonding is an absolute must.
/ Tractor is dead...help #27
I have a 2014 new holland boomer 24. When I go to start tractor there is nothing....no lights, no clicking, nothing. Tractor is completely dead. I have bought a new ignition switch and replaced the battery. The wiring harness has juice as we tested that. Dont know what else it could be....someone please HELP....I'm desperate to get this tractor going asap as I need it to feed my horses.
I'm going through the exact same thing with my Jinma 284. Sorry!
/ Tractor is dead...help #28
yo;u guys must have a lot of money just replacing all the parts etc.
and not checking to see what is actually wrong.
Read the other posts about dead tractors.
If all else fails I can loan you my shovel
willy
2013 HPX Gator 4x4 Gas Utility Cart (A61567)
2013 HPX Gator 4x4...
2024 JCB 35Z (A60462)
2019 Krause 8005-30 Excelerator - High Speed Vertical Tillage - 30 FT Working Width (A63118)
2019 Krause...
BUNDLE OF 10' RE BAR (A62131)
BUNDLE OF 10' RE...
2021 John Deere W48R Walk Behind Zero Turn (A63116)
2021 John Deere...
BUNDLE OF (1) TOPLINK & (2) LIFT ARMS (A62130)
BUNDLE OF (1)...
