tractor identifacation
/ tractor identifacation #1
marty 1950
essex ontario
ferguson
i just bought a ferguson tractor and need some help as to what i have the serial #iea 010367 tag said it was built in coventry uk standard motor company i think it is 85 mm bore any help on year and what model is greatly app thank marty1950 idont know how to post a picture
/ tractor identifacation #2
Welcome ... Posting a picture would be very helpful.
/ tractor identifacation #3
I think we are going to need more info. And perhaps some pics.
/ tractor identifacation #4
/ tractor identifacation #5
We definatally need more feedback from the OP to really narrow this down.
For starters, IF that is the serial number, I am betting that the first 0 is wrong. Could it be anything else from a 1 to a 5??????
Second, IF it is a TEA, then yes, that is a tractor built in england. The TO's were the american version. And the TE's were england. A note on tractor data says that when they dropped the continental engine and went to the standard engine in 1947, it became the TEA.
Now you say yours has the standard engine. and 85MM bore. (BTW, how do you know it is an 85mm bore???? Does it say somewhere on the engine???)
Anyway, the 85mm bore standard engine started at serial #172598.
So either you may have a tractor that had a replacement engine. OR, you have to have a serial number that is higher than 172598 for things to make sense.
A serial number in the 10,000's is only 1947's, which still would have been the continental engine or the standard 80mm bore.
A serial number in the 10,000's is only 1947's, which still would have been the continental engine or the standard 80mm bore. i measured the bore and it was 85mm
2017 Ford Escape SUV (A61574)
2017 Ford Escape...
(2) 460R85R38 TIRES W/ (8) LUG WHEELS (A64280)
(2) 460R85R38...
40' New Container (A62679)
40' New Container...
(1) 235/80R16 TIRE W/ (8) LUG WHEEL (A64280)
(1) 235/80R16 TIRE...
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A63569)
2020 TROXELL...
Crary Air Reel Cables (A63117)
Crary Air Reel...
