Buying Advice Tractor for large garden
/ Tractor for large garden #21
/ Tractor for large garden #24
They seem to be about the same size as my BX, no?
More ground clearance..............makes a huge difference when cultivating.
The Bolens has 'roughly' a 12 inch ground clearance...........the BX series has about 6 inches. Thats a lot when working with growing plants.
EDIT: The OP has the right idea.......
A farmall cub, or an old Powerking/economy tractor has a 24 inch ground clearance............great for garden work.
/ Tractor for large garden #25
Personally I would look into a farmall cub or similar with cultivators. I use my 8N with plow and disc to work the ground and my cub for cultivating once the rows set and plants in the ground. It seems as though with your JD you would have all tillage taken care of and if not a cheap used plow and disc or a tiller would be easy to find for the 3pt instead of trying to find everything for a new smaller tractor. If you are looking antique then I think an Allis G or cub (or any other tractor designed for cultivation) would be the way to go.
After reading all the posts, I think this would be the way to go :
1- JD : All the ground work (I already have one used JD plow that I picked up last year and a disc that need some repairs and new paint)
2- A Cub of something similar for the cultivation
Thanks for all the inputs.
Be safe
Lecoq
2017 Ford Escape SUV (A61574)
2017 Ford Escape...
2021 CATERPILLAR 299D3 SKID STEER (A64279)
2021 CATERPILLAR...
2020 Freightliner 114SD T/A VacCon VPD3611 Combination Sewer Jetter Vacuum Truck (A61573)
2020 Freightliner...
2018 Volvo VNL T/A Sleeper Cab Truck Tractor (A61573)
2018 Volvo VNL T/A...
2015 John Deere 310SL 4x4 Extendahoe Loader Backhoe (A61572)
2015 John Deere...
2020 CASE TV450B SKID STEER (A64279)
2020 CASE TV450B...
