Tractor Distribution
/ Tractor Distribution #21
</font><font color="blue" class="small">( John Has it gotten any easier to engage and disengage the 4wd as the tractor borke in? It is not a really big deal but you really have want to use 4wd to engage it.
)</font>
As I said in my last post, it's sometimes necessary to move the tractor forward or reverse a little if you're having trouble getting it to engage. Sometimes they don't quite line up just right and you need to move a little. I don't find this to be an unusual problem, it's common in a shift like this.
Unless your tractor has some type of adjustment problem, if you try what I said, you should be able to easily get it to change. Try it, if it doesn't engage, move up a little and try it again. Sometimes I've had to move a few times before it gets in the right orientation to move into 4WD. It's a gearing thing. Make sure you push in the clutch before moving the lever.
If you continue to have troubles after that, have the dealer check it out, as it will probably need to be adjusted under warranty. John
Kubota SVL 97-2 (A53317)
Kubota SVL 97-2...
Sterling AT (A61307)
John Deere Z997R (A60462)
John Deere Z997R...
Case IH 800 (A60462)
MGY Shop Heater (A60463)
MGY Shop Heater...
2013 Chevrolet Silverado 3500HD Enclosed Service Truck (A60352)
2013 Chevrolet...
