Tractor Closet!
/ Tractor Closet!
UPDATE! Bought a new camera Cannon D1200 with some nice lenses. Here's some more photos of................................................. TRACTOR CLOSET!!!
/ Tractor Closet! #22
When I bought my JD 5420 it had a nifty toolbox mounted on the right side by the driver access step. Unfortunately, this had to go away as it was in the way for the front end loader bracket. I made a bracket and mounted it behind the driver...but it is somewhat in the way when you are backing up to a piece of equipment. It is hard to see to align the lift arms. Looks like some of your 'inventions' have that same limitations? All good ideas, though.
/ Tractor Closet! #23
I put a military ammo box toolbox on the RH fender of my JD 790. It is/was perfect. But now it has shrunk. (I try to put too much in it...snicker)
/ Tractor Closet!
No, mines high enough so that you can easily look under it to see all points behind you, both high and low. I also added mirrors at the corners of the canopy, not pictured, that work great too, for seeing behind you. Oh ya.... I thought of everything here!
/ Tractor Closet!
Hate that when that happens!
