Tractor Closet!
/ Tractor Closet!
UPDATE! Bought a new camera Cannon D1200 with some nice lenses. Here's some more photos of................................................. TRACTOR CLOSET!!!
/ Tractor Closet! #22
When I bought my JD 5420 it had a nifty toolbox mounted on the right side by the driver access step. Unfortunately, this had to go away as it was in the way for the front end loader bracket. I made a bracket and mounted it behind the driver...but it is somewhat in the way when you are backing up to a piece of equipment. It is hard to see to align the lift arms. Looks like some of your 'inventions' have that same limitations? All good ideas, though.
/ Tractor Closet! #23
I put a military ammo box toolbox on the RH fender of my JD 790. It is/was perfect. But now it has shrunk. (I try to put too much in it...snicker)
/ Tractor Closet!
No, mines high enough so that you can easily look under it to see all points behind you, both high and low. I also added mirrors at the corners of the canopy, not pictured, that work great too, for seeing behind you. Oh ya.... I thought of everything here!
/ Tractor Closet!
Hate that when that happens!
POLY TANK ON SADDLE MOUNT (A62131)
POLY TANK ON...
HUSKIE HYD HAMMER (A62131)
HUSKIE HYD HAMMER...
1979 AM General 6X6 Truck (A61165)
1979 AM General...
Trump 2028 Metal Decorative Sign (A61569)
Trump 2028 Metal...
2022 John Deere X730 Lawn Mower (A63116)
2022 John Deere...
Dad's Garage Decorative Metal Sign (A61569)
Dad's Garage...
