Tractor chains for snow and ice advice
   / Tractor chains for snow and ice advice
Someday I’ll retire this tractor to easy farm work like haying, berry picking, brush cutting, and tractor rides.😜
Meanwhile, here is a few pictures of what it gets to do.
   / Tractor chains for snow and ice advice #33
Hello and thanks in advance.
Just looking for advice on what to get for my tractor this winter…that won’t cost me a fortune 😬
I have a fairly steep and approximately 15’ ridge to climb while hauling logs out. Logging my property for past couple years and selling firewood as I go. With a pto winch I can do so through the winter too and just plow the logging road I made.
The land is mostly flat but this ridge is going to a pain this winter.
I will be bending my fenders out to make enough room for the chains. But chains need to be tight or it could end badly. So i am particularly worried about the ladder style and any slop from them.
Definitely looking for advice from people with experience dealing with different chains in snow and ice. We get about 12’ if snow average around my area.
Here are possible options at this time:
My local Branson dealer has these for $643
Ladder style from Quality Chains
Glacier Chain Supply in Anchorage has these for $877
Aquiline MPC (Multi Purpose Chains)
I can get these Piedmont Duo style from Tirechainsonline for $600 with free shipping to Tacoma Wa where Carlile MyConnect shipping can ship it to their Anchorage terminal for around $60.
When I was installing chains on my Ford 1210 4WD for use on extremely hilly terrain, I learned I needed the ‘2 link’ kind not the ‘4 link’ kind. That’s the spacing for the cross chains as the attach to the side chains. Getting them on right and tight is critical or you’ll end up lying on the ground far from your maintenance building. I modified some turnbuckles to tension the chains on the outside of the wheels during installation. Then used another turnbuckle the tension the last connection on the side chain and used a CLEVIS to finally put those outer chains together. I found the clevis gave me the tightest chains.
I had steep clay soil where it was difficult to even walk when it was wet. Those chains never came off all four wheels.
   / Tractor chains for snow and ice advice #34
That's probably the best way to do it, rather than bending the crap out of fenders to make room.
Pretty sure the fenders and floor of the cab are integrated, molded plastic parts, one per side with a seam in the floor. OP, have you tried putting a magnet on the finder to make sure it is metal. Are the fenders about 1/4-inch thick? If so they are plastic. Cutting or trying to bend the plastic can result in cracking. If you cut off the rim, the fender will probably crack.
Good things about the plastic body panels are: If they fade, they polish out, and you can't polish off the color coat, because the color is integral to the plastic. And, they are impossible to dent, might break, but won't dent or rust.
Yes, they are metal. The Branson (mine is a 4520r) was a little more beefy than comparable ones from other brands. Why I chose it…along with no computer so I can work on it and eliminate the DPF when the warranty is expired and cheaper price.
   / Tractor chains for snow and ice advice #36
Haul out your logs BEFORE Winter. No chains overcome 12' of snow.
   / Tractor chains for snow and ice advice #37
Maybe not, but lots of logging done once the ground is frozen, as you're not destroying the ground making ruts, or getting buried in mud!
And snow cover is "removable"! :cool:
   / Tractor chains for snow and ice advice #38
Not a logger, just doing my own 10 - 15 cords per year, but I try to as much as I can while the ground is frozen.
We run teens overnight, up to maybe 30F afternoon high, much of the winter. Just warm enough that the surface thaws with a little solar warming, wherever the sun lays into it, most afternoons. This means a lot of "get up and outside" early morings on winter weekends, to try to avoid having to work firewood thru the afternoon.
At $280 a cord, it’s my livelihood and I have several customers who need it through the winter. I’ve push 18” of snow around without chains. I make roads through the property and plow it through the winter. The skidding winch on the rear has 230’ of cable and I hyst snowshoe out, cut the trees, and pull them out 3 at a time.
RIPPER ATTACHMENT FOR MINI EXCAVATOR (A58214)
RIPPER ATTACHMENT...
Yamaha Kodiak ATV (A59814)
Yamaha Kodiak ATV...
2008 MAXX-D FUEL TRAILER (A58214)
2008 MAXX-D FUEL...
Toro Three wheeler sand pro (A56859)
Toro Three wheeler...
SKID STEER ATTACHMENT SIFT BUCKET (A58214)
SKID STEER...
2010 MAXEY WELDING 20 T/A GOOSENECK TRAILER (A55745)
2010 MAXEY WELDING...
