Tractor Buying advice
/ Tractor Buying advice #1
turfking
Hi, I'm new to this forum and need some advice. I am the owner of a part time lawn service, I am thinking of expanding my business to offer wide area mowing and bush hogging, the latter will include pastures and right of ways. I need advice on a tractor capable of running up to a 15 foot heavy duty cutter. Any help would be appreciated.
/ Tractor Buying advice #2
15ft? heavy duty cutter? you sure ain't going to that with a 30hp tractor. your are talking a serious machine. plus u have to be able to move it from one place to another, so again u are talking some serious equiptment. have u checked out anything that would be able to do that kind of work? see dealers for that kind of info. sorry i can't be more help.
/ Tractor Buying advice #3
I guess you're talking about using a 15' batwing mower. You don't need a compact tractor for this as much as you need a medium size ag tractor like a JD 5410 or 5420.
Sorry, linked to this site from another. I did not realize this was a Compact tractor site. I need a tractor from 50 hp up.
/ Tractor Buying advice #5
You might want to read this post.<A target="_blank" HREF=http://www.tractorbynet.com/cgi-bin/compact/showflat.pl?Cat=&Board=genoperating&Number=126456&page=&view=&sb=&o=&vc=1> click here </A> I know you are very specific in wanting to run a 15' cutter, but this thread describes a way to get wider cuts with smaller machines, which you might already have. I believe this is the way to go for a nicer appearance than a rough cut might give. And it is much more versatile in that you can narrow it down to less if you need to do an area that is too big for the 15' machine.
I understand that it might not work in pastures as they are only cut a few times a year, but this is still interesting and might fit the bill for other work that you perform.
Hope this helps. Keep us informed as to your thought process and decision.
KBH Tender Trailer (A63688)
KBH Tender Trailer...
Like New! Kubota L2501 HST Tractor Package – LA525 Loader, RCR1260 Cutter
Like New! Kubota...
UNUSED SDLANCH SDLGC80 ELECTRIC GOLF CART (A64280)
UNUSED SDLANCH...
ZERO TURN LAWN MOWER (A64280)
ZERO TURN LAWN...
2016 Ford F250 Crew Cab Service Truck (A64194)
2016 Ford F250...
2023 Takeuchi TL6R Compact Track Loader Skid Steer w Low Hours (A63689)
2023 Takeuchi TL6R...
