Xfaxman
Super Star Member
- Joined
- Feb 8, 2013
- Messages
- 13,322
- Location
- Guthrie, OK
- Tractor
- Toolcat 5610 G - Bobcat V417 - TORO+Loader
They show up fine on my ChromeBase computerI don’t see pics
I'm new to T-net. I cannot view your pictures. what do I need?Thanks. Yes, I draw my parts alone and then buy material and go to a local workshop where they cut it with a CNC plasma cutter
....and it clearly shows!Thanks, I've put alot of time into it
Your projects remind my of my Canadian cousin who took part in the local tractor pull with a Massey Harris 44. He got his hands on a cracked cylinder head, put it under the mill at work and milled it untill the coolant channels became open. Then he took his good head and milled slightly less than the depth at which the coolant channels were through. This upped the compression from 1:4.5 to 1:11 so he had to run it on racing gasoline. The cast iron exhaust manifold was recreated in tubular steel and sheet metal, and aged by dropping it in salt so it looked original.Thanks, I've put alot of time into it
