Tractor backhoe - homemade
/ Tractor backhoe - homemade
Moving on rapidly, I made some pins and bushings and here is the main lifting cylinder in place
And this will be max height position
delete repeated words
Tomorrow I'll attach 2nd boom and hopefully both cylinders
/ Tractor backhoe - homemade #1,342
Looking good, I see you got your reflection engraved it the main lift boom........
That's just a mark after some grinding
/ Tractor backhoe - homemade #1,344
Oh so your an artist to thats awesome:thumbsup:
/ Tractor backhoe - homemade #1,345
The holes in the boom where the pins go do not seem to have any reinforcing. The backhoe I have has short pieces of DOM welded in, but looks like the hole is bigger so it may be a method for ensuring alignment in production. Are you planning to add DOM or other reinforcing to the holes?
I'm not sure I understand what kind of reinforcement do you mean...? All the holes have bushings with 14 mm thick walls...
/ Tractor backhoe - homemade #1,347
I thought the bushings was the reinforcement and a better reinforcement....
/ Tractor backhoe - homemade #1,348
This is what I was thinking of. I do not know what the best way to do this is. I do make some things, but not on the scale or quality that you are doing so my question was only for information so I can improve on my work.
/ Tractor backhoe - homemade #1,349
Must be talking about that plate welded around the bushing, but how does one know enough is enough for reinforcement......
/ Tractor backhoe - homemade #1,350
The OP massively thick boom plates rather dwarf the pin bushings from a typical tractor backhoe.
Very impressive work and awesome fabrication skills.
3Ts, you refered to this reinforcement? I'm using thise at hugh stress areas
Connected and aligned all boom sections
best image host
html upload image
Future operators view
Yes, well I said before it will be a tripple boom style. Many excavators use this kind of boom, especially "city" types. This way you get maximum reach and height, but you can also dig in tight places, near walls etc.
/ Tractor backhoe - homemade #1,354
Many............ Maybe over there, but over here It took me 10 minutes just to find a picture of a triple boom back hoe and wasn't even on a tractor, this back hoe build will be interesting when all done next year epically if it works. No pressure but the whole world is watching...
/ Tractor backhoe - homemade #1,355
Indeed it is unusual to find a triple boom on a TLB, but on excavators in the 12-20 ton range it is quite a popular option. Cat offers it up to the 323, the company i work for builds them for Cat 330. On bigger machines the middle arm cylinders are mounted below the boom, because they will penetrate on boom weight alone, and lifting it is a bigger challenge (with the stronger bottom end of the cylinder)
Here is one on a beefed up Cat 390, now weighing 140 ton
4K | Cat 390F STC Triple | Lock demolition Meppelerdiepsluis | Beelen Sloopwerken / Vlasman B.V. - YouTube
Considering my experience with the previous rk-525 backhoe, I decided to make tripple boom because I think it will give the most out of the machine. It will be able to dig close to the tractor, as far as possible and as high as possible. You said you never saw this type of boom on a tlb, ok so let's do it now for the first time. ;) Let's break the limits. I plan to make a log splitter clamp for it, so this reach and height will come in handy when lifting logs...
/ Tractor backhoe - homemade #1,357
Very interesting! And, yes the reinforcement looks good. I missed it in the earlier photos. I've never seen a triple boom, I'll be watching your build.
/ Tractor backhoe - homemade #1,358
Those are big machine seem to work good in tight quarters where travel is limited. When BFreaky does get his built it might be the only one on a tractor in the world, I cant find one on a tractor anywhere...........
/ Tractor backhoe - homemade #1,359
I hope when this back hoe is done it will be on video, it's starting to sound like a pop corn movie........
/ Tractor backhoe - homemade #1,360
Definitely will be the first one on a tractor for sure. They don't even make it for backhoes either. Mostly excavators.
Check out Mecalac and Wacker Neuson exacavators. Both have tiple boom setups on a much smaller scale that what Renze shown.
2002 International 9200i Truck (A61307)
2002 International...
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2019 CHEVROLET...
2012 John Deere 328D Compact Wheel Loader Skid Steer (A61572)
2012 John Deere...
2025 48in Drum Mulcher Skid Steer Attachment (A61572)
2025 48in Drum...
2001 Peterbilt 330 4,000 Gallon Water Truck (A64194)
2001 Peterbilt 330...
2025 72in Hydraulic Grapple Rake Skid Steer Attachment (A61572)
2025 72in...
