Tracked loader pictures
/ Tracked loader pictures
Larry,
It came with a bucket and no air. The first order of business this spring is to remove the door. The windows slide down as well.
Had some money burning a hole in my pocket last fall so I ordered a New Holland TN utility tractor- probably similiar to your M6800. Decided to cancel when he found out it was 3 months for delivery and I rationalized the loader based on less overlap with my present tractor.
I do some excavation for Habitat for Humanity and a tractor is too cumbersome on those small lots. Also I've got a narrow driveway and creekbed that when you need to be perpendicular, there just isn't room with a conventional tractor.Also twelve acres of regrowth that needs to be selectively thinned. I'd like to make a tree shear but may buy it instead. Then there is trimming around all those trees worth saving and it takes forever with the tractor. With the loader you can essentially move the mower sideways in addition to forward and reverse. Even though it has low compaction, it scuffs up the sod when you turn sharp so we'll see how well the grass recovers from that.
John
/ Tracked loader pictures #12
John,
That should work out pretty well for you. Sounds like a better fit for you than the NH-TN since you already have a conventional tractor. The skidsteers sure are more maneuverable in the tight spaces.
It will be nice to have for the Habitat for Humanity jobs. I'm hoping that one day I will have some time available to get involved in that. I put myself through college working as a carpenter and property maintainance man and wouldn't mind bending a few nails for a good cause.
The tree shear sounds like an interesting project. There were a lot of BIG tree shears around where I grew up in northern MN. Logging was pretty big business there. It would definitely be useful for selective cutting since you can take it out vertically and choose where to lay it rather than felling through the rest of the stand.
Have fun with the new toy and post some action pics in the Projects section. /forums/images/graemlins/smile.gif
/ Tracked loader pictures #13
Looks like a tank.
One question.
Due to the short track length, do you feel the machine rock front to back, feeling like it wants to tip into its front or rear. I test a Takeuchi TL150 and a ASV RC 100.
The Takechi was NO comparision to the ASV. Much smoother ride, more productive, great track life, high flow (brush cutting, snow blowing) unbelievable manueverabilty. Better preformance, HANDS DOWN
/ Tracked loader pictures #14
Here is a real track loader. 8 inch longer track, more wheel contact points, less ground pressure, high flow (40 gpm), undercarriage suspension (really smooth ride, increases productivity) track life over 2000 hrs,
THIS IS MY BABY!!!!!!!!!!!!!
2004 JOHN DEERE 160C LC EXCAVATOR (A59823)
2004 JOHN DEERE...
2017 PJ TRAILER 20' T/A TRAILER (A58214)
2017 PJ TRAILER...
2011 Freightliner Cascadia 113 S/A Day Cab Truck Tractor (A59230)
2011 Freightliner...
1990 Ingersoll Rand 175 S/A Towable Air Compressor (A59228)
1990 Ingersoll...
2018 John Deere Z997R (A53317)
2018 John Deere...
2016 John Deere 4044R 42HP 4WD Utility Tractor (A59228)
2016 John Deere...
