Track performance in snow
/ Track performance in snow #1
Dunmovin
Looking at a T190 but have been told that the standard rubber tracks don't perform well in snow. Wondering whether I should look into an S185 and perhaps add steel over tire tracks.
Have bush block with steep sections (mostly dry loose material not much mud) with the local Bobcat dealers recommends a tracked Bobcat only. Does anyone have experience or recommendations with tracked verses over tire tracks?
Dunmovin
/ Track performance in snow #2
Rubber tracks work great in the snow.
They fail in ice!
They fail in ice!
Appreciate that but then how do you solve the ice problem (Bobcat Dealer described them as a toboggan !). On a tired skid steer chains are the solution. What's the solution for tracker loaders?
Txs
Dunmovin
/ Track performance in snow #4
Hey Dunmovin, what are, is bush blocks? I like my over the tire tracks for the mud and gen. dirt work, and tire chains for in the snow. The tracked machine may provide a little bit of float on the snow but for traction you can't beat tire chains. I'll take that one more step by saying that for the OTT is way better for traction in the woods and "greasy" mud, but they clearly loose to a track machine on flotation in the very deep goo! Way less $$ initally and in the long run too.
Rustyiron
You've confirmed by suspicions - I'm in the interior of southern BC, Canada and it's either snowing in winter or pretty dry in summer so mud is not a really issue. Ground tends to be dry loose material. For much of the year tires should work perfectly and i prefer the flexibility of chains winter and OTT if the conditions get really loose or muddy
Many thanks
Dunmovin
/ Track performance in snow #7
my friends t190 (standard sq pad tracks) that i drove this winter to do farm chores, absolutely SUCKED in the snow. even the smallest incline (like just a few inches over 8-10' pad in front of the garage) brought the machine to a stand still and had it sliding around uncontrollably.
and nothing to put chains on....
/ Track performance in snow #8
Tracks are bad in snow. You need the ground pressure to get traction in snowly/icy conditions.
So, I assume a skid steer with tires is better? I know nothing about the subject, so please don't take my questions as being rude. I am completely ignorant! Would a skid steer be a better choice for moving snow, etc that a tractor with R1?
/ Track performance in snow #13
chains are good.. hard on asphalt... but good.
Just as I expected. I saw the damage chains can do on asphalt when I lived in Washington State.
All the ground I have to run on is dirt and or gravel. So chains should be okay?
Doc
/ Track performance in snow #14
A Bobcat with steel tracks will out push, out work most anything else. I have owned two Bobcats with the Steel tracks, they bite into snow AND dirt to give amazing traction. They slip like ice-skates on ice and other hard surfaces though. They also will tear up a lawn a bit depending on how sharp you turn.
/ Track performance in snow #15
Great information. How easy/hard is it to mount the steel tracks and take them off?
Doc
/ Track performance in snow #16
Caveat skidloaders are great for snow But they lack the reach of a tractor loader for piling high.
I usually run a wheeled skidloader for snow it's quicker & smaller than ag tractor with loader & blower.
/ Track performance in snow #17
I have used my Dad's John Deere CT322 (standard rubber tracks) to plow snow and had a very bad experience. I was plowing on our driveway (1/3 mile of incline and 20 feet of flat) and about slid down the hill. The only way to stop was tilt the bucket all the way forward and get a good bite at the ground. We used the John Deere 3720 with front chains only and plowed the whole driveway without slipping once and we even lost the chains on the right side! Tires are much better. :thumbsup::eek: Sounds like what you need is an S185 with tire chains and possibly steel tracks. :)
/ Track performance in snow #19
If someone needed traction on ice, the Bobcat/Grouser steel ott tracks do have holes in them for optional spikes, probably like what you can add to snowmobile tracks.
Refreshed my mind and they are not like a snowmobile's.
/ Track performance in snow #20
They look like serious spikes. Imagine they would do quite a bit of harm to asphalt :D
(UNUSED) JOHN DEERE RC10R ROTARY MOWER (A64278)
(UNUSED) JOHN...
2014 Ram 2500 4x4 Crew Cab Pickup Truck (A64194)
2014 Ram 2500 4x4...
2021 TAKEUCHI TL6R SKID STEER (A65053)
2021 TAKEUCHI TL6R...
2022 EZ-GO ELITE...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
2009 Chevrolet Silverado 2500 Crew Cab Pickup Truck (A64556)
2009 Chevrolet...
