Towing
/ Towing #11
???? Mis typed?
The tires are only one link in the chain. Where does the tongue weight issue come into this?
/ Towing #12
I interpret (and this is only me thinking) that he means in theory that for example you put 7500lbs on the trailer and situate it so that 300lbs of that weight is transferred to the tongue (tow vehicle) that in essence means you only have 7200lbs on the trailer which is the rating of the tires originally mentioned. In theory although highly impractical you could put 10000lbs on the trailer and situate it that 3000lbs of that weight was on the tongue and you would not be overloading the trailer until you jumped in the truck and started to move.
Steve
/ Towing #13
I thought he was saying the tongue weight does reduce the tire load. I wouldn't push it to within a few hundred pounds of their limit. Too many bad things can happen if you have a flat on a trailer hauling 5000+ lbs of cargo.
2016 Hyundai Veloster Hatchback (A59231)
2016 Hyundai...
2017 Dodge Charger Sedan (A59231)
2017 Dodge Charger...
CAT930K (A58214)
CAT930K (A58214)
Kubota SVL 75-2 (A53317)
Kubota SVL 75-2...
UNUSED FUTURE FT-RP72 - 72" HYD ROCK CRUSHER (A52706)
UNUSED FUTURE...
2004 Mitsubishi Endeavor AWD SUV (A59231)
2004 Mitsubishi...
