Towing Questions
/ Towing Questions #31
I used three high capacity scales to measure my tractor and trailer setup. I feel much more comfortable after actually weighing it all. I wanted individual weights to use for later rather than loading up and going to a weigh station.
It turns out that I am A-OK on all weights and tractor tongue weight, so my comfort level has increased. I'd recommend going to a weigh station rather than simply guessing. (And, I'd add that I know the possible outcomes of just figuring out (guessing) for yourself. It can hurt.)
Or your local gravel pit or landscape materials lot. They usually have a truck scale they don't care if you use if they aren't busy.
/ Towing Questions #32
Yes, I was off. It looks more like 7850#. The tractor is listed at 4,224#, the loader is 1,300#, the bucket is 322#, the (2) loaded 17.5L-24's are 913# total, then add 1,095 for the mower. It looks like the real weight is about 7,850, so I'd figure about 8,000 for the load. Overall, I guess y'all have confirmed what I figured: I'm better off not doing it. And I'd rather learn that here than on the side of the road. I've been down the road of trading up to a 3/4 ton to tow a specific load and I won't do that again. It's not worth the cost. The question was asked because I've leased some land 8 miles away. I only need the tractor at that property 4 times per year. I'm probably better off just taking the extra hour to ride the tractor.
8 miles one way ? Kick the tractor into 2 wheel drive and hi gear and in 30 minutes your there. Rough roads and such as you mention even at a hour it probably take you that that long to hook up a Trailor and load the tractor and tie it down and then unload and unhook it all.
/ Towing Questions #33
Lots of talk about towing capacity but I don't see anyone mentioning total COMBINED vehicle weights. GCVW is everything, your truck (and all that's loaded in it) and then the trailer and all its contents. Your trailer could be under max but you could still be over if you have a lot of stuff piled in the truck.
I'd mentioned to someone else in a similar bind to RENT a truck. I believe he reported back that that's the direction he was going to go with, that the cost really wasn't as much as he thought it might be.
I like the idea of hitching up an ATV/UTV to the back of the tractor. If you encounter an emergency situation the tractor is likely going to be way too slow to get you to help. (of course, most would want something other than what I have -Polaris Brutis [HST], which can only be counted on for about 25 mph [assuming not going up hill!])
/ Towing Questions #34
When I bought my case JX-95 I didn't have a trailer that could handle t so I drove it home - 110 miles. It took about six hours but I got real acquainted with it and had a cab and AC / radio so I didn't mind.
/ Towing Questions
Wow, that is a long ride. BTW. I went over and did my last work for this year last weekend. No big deal. For 4 or 5 trips a year at 16 miles round trip, I'll just continue to ride. Thanks for the replies, guys.
2016 John Deere 6110M (A60462)
2016 John Deere...
2002 Frieghtliner Pressure Digger Truck (A55973)
2002 Frieghtliner...
Brock 48'x16' Flat Bottom Grain Storage Tank (A57148)
Brock 48'x16' Flat...
2016 Troy-Bilt 18in. Push Mower (A60352)
2016 Troy-Bilt...
2011 MAGNUM PRODUCTS LIGHT PLANT/TANK TRAILER (A58216)
2011 MAGNUM...
2019 FORD F-150 XL SINGLE CAB TRUCK (A59823)
2019 FORD F-150 XL...
