Towing Capacity for Aerator?
/ Towing Capacity for Aerator? #1
KYCOLONEL
Mahindra 3015
I have a Toro rider 17 hp- 44 and am considering pulling a plugger aerator behind it this weekend (It's either that or rent a walk behind). The aerator weighs 119 lbs. and you could add up to 250lbs more in weight if needed. I need it to aerate about 1 acre of mostly flat ground.
The question is- how much can I safely tow with my 17 hp garden tractor using the factory hitch? At what point should I worry about overstressing the mower pulling the "dead weight" of an aerator?
Any advice is appreciated.
Thanks.
/ Towing Capacity for Aerator? #2
How wide is the aerator? Given it's weight, I am inclined to think it might be designed for a heavier frame Garden Tractor with a stronger transmission. I pull a 40" tow-behind plug aerator (weighs about 70 lbs) loaded to maximum with approx 175 lbs of bricks using my 15hp John Deere LT155 tractor. The aerator manual also covers a 48" model that can hold up to 250lbs of extra weight. It clearly says the 48" model should only be pulled by a "Garden Tractor" class machine. I have aerated my mostly flat 1.5 acres 3 times with the 40" setup and my tractor seems to have no problems pulling it. Comparing the MSRP from the Deere and the Toro websites, I would say we have similar class machines.
7' Pallet Fork Extensions  (A62679)
7' Pallet Fork...
2018 PETERBILT 567 (A65643)
2018 PETERBILT 567...
Skid Steer Blank U-Plate (A65640)
Skid Steer Blank...
2022 SWARTZ 100" X 40' GOOSENECK TRAILER (A64276)
2022 SWARTZ 100" X...
Michelin Floatbib VF1000-55 R32 Equipment Tires (A64194)
Michelin Floatbib...
master diesel generator (A64553)
master diesel...
